dirtyacc Posted September 4, 2019 Share Posted September 4, 2019 i like the float toolbar which will automatic show up in refedit instead of the contextual ribbon,but how can i like the toolbar to the refedit command just as the old classic userinterface? Quote Link to comment Share on other sites More sharing options...
maratovich Posted September 4, 2019 Share Posted September 4, 2019 Run the -TOOLBAR command with the “-” symbol, this is extremely important! Enter the name of the panel, for example, Standard (Standart) or Draw (Draw) Select the option Show (Shaw). The coveted panel appears in the workspace. Hiding the ribbon with the RIBBONCLOSE team Enable the drop-down menu by setting the value of the variable MENUBAR equal to 1 (0 - disabled) Right-click on the panel and turn on all the other necessary panels. For full compliance with the classic interface, you need to open the Standard (Standard), Styles (Styles), Layers (Layers), Properties (Properties), Draw (Edit), Modify, Workspaces (Worspaces). We arrange the panels on the working field (the panel bindings work!) Save the current workspace under the name, for example Classic interface Enjoy! Quote Link to comment Share on other sites More sharing options...
dirtyacc Posted September 4, 2019 Author Share Posted September 4, 2019 1 hour ago, maratovich said: Run the -TOOLBAR command with the “-” symbol, this is extremely important! Enter the name of the panel, for example, Standard (Standart) or Draw (Draw) Select the option Show (Shaw). The coveted panel appears in the workspace. Hiding the ribbon with the RIBBONCLOSE team Enable the drop-down menu by setting the value of the variable MENUBAR equal to 1 (0 - disabled) Right-click on the panel and turn on all the other necessary panels. For full compliance with the classic interface, you need to open the Standard (Standard), Styles (Styles), Layers (Layers), Properties (Properties), Draw (Edit), Modify, Workspaces (Worspaces). We arrange the panels on the working field (the panel bindings work!) Save the current workspace under the name, for example Classic interface Enjoy! OK, now I know how to bring it out. One more question, how can I link a toolbar to contextual workplace like the classic interface is? I mean, the reference edit toolbar show automatically only when I go in a refedit Quote Link to comment Share on other sites More sharing options...
tombu Posted September 4, 2019 Share Posted September 4, 2019 (edited) While there are Ribbon Contextual Tab States with display options it's not possible with Toolbars. Honestly cannot remember when I used a Toolbar or a Menu Bar, it's been years at least. Once you go Ribbon you never go back. Edited September 4, 2019 by tombu Quote Link to comment Share on other sites More sharing options...
