cartographer
Rotating Text around base point based on azimuth of 3D polyline
cartographer
Hi guys & gals,
I came across a very repetitive problem. While working with a certain type of software data is output to *.dxf as set of 3D polylines and text. From the level of software I work with, I cannot configure any text formatting details. Hence an idea to ask You few questions.
1. Is there any way of rotating text based on azimuth of a 3Dpolyline which lies within 0.3m distance from the text base? Did someone ever came across LISP of this type ?
2.  is there any other (more effective) way than OVERKILL to get a rid of duplicated text ?
Thank you in advance !
Regards,
Adam, Geophysicist.
Share this post
Link to post
dlanorh
Quote
1. Yes the following will return the angle of the 3dpolyline at it's start point. Just paste to the command line, press return and select the 3dpolyline. The return is an angle in radians. It obviously gets more complicated if segment angles change.
 (angle '(0.0 0.0 0.0) (vlax-curve-getfirstderiv (car (entsel)) 0))
2. Yes there are other ways of deleting duplicate text. Make a list of all text, sort by insertion point coordinates then compare text string value. Whether it is more effective is subjective.
Share this post
Link to post
