REQ : lisp to draw polyline rebar end hook side indecator
Abdulellah
Not sure what your point is. I have no problem with using command calls.
But I must correct you here:
1 hour ago, BIGAL said:
Yes probably worth adding a osmode 0 to code.
It is absolutely essential to handle the OSMODE setting when using command calls.
Edited by Roy_043
15 hours ago, BIGAL said:
This is latest has offset radius and angle pick pline anywhere.
(defun c:plhook ( / plent pt1 pt2 pt3 pt4 ang3 pt5 add ang1 ang2 ang3)
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(if (= but nil)(setq but 1))
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(while (setq plent (entsel "Pick pline Enter to exit"))
(setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))
(setq pt1 (nth 0 co-ord)) ; 1st point
(setq pt2 (nth 1 co-ord)) ; second point
(setq x (- (length co-ord) 1)) ; how many points- 1 as 1st point is 0
(setq pt3 (nth (- x 1) co-ord)) ; second last point
(setq pt4 (nth x  co-ord)) ; last point
(setq ang1 (angle pt2 pt1)) ; angle ofthe pline
(setq ang2 (angle pt3 pt4))
(setq ans (AH:getvalsm (list "Enter length" "Hook length " 5 4 "30" "Radius" 5 4 "25" "angle " 5 4 "45")))
(setq add (atof (nth 0 ans)))
(setq rad (atof (nth 1 ans)))
(setq ang3 (* pi (/ (atof (nth 2 ans)) 180.0)))
(setq pt5 (polar pt1 (+ ang3 ang1) add)) ; 135 degrees
(command "line" pt1 pt5 "") ; new line
(setq ans (ah:butts but "V" '("Flip  " "Yes" "No")))
(if (= "No"  ans)
    (princ "ok")
    (command "mirror" "Last" "" pt1 pt2 "Y")
(command "pedit" (car plent) "join" (entlast) "" "")
(setq pt5 (polar pt4 (+ ang3 ang2) add)) ; other end
(command "line" pt4 pt5 "")
(if (= "No"  ans)
    (princ "ok")
    (command "mirror" "Last" "" pt4 pt3 "Y")
(command "fillet" "Polyline" "r" rad  (car plent))
(c:plhook)
dear begal i am sorry to say that <
- forget dcl window realy it make slow work . return for frist code it its good  , discard dcl window make me stay on command prompt
- at general my work in meter ( 1 autocad unit = 1 meter ) work with digits assume hook length = 0.03 m
- lisp must remember last entries and entries must be as subcommand  when lisp ask me to pick polyline like any autocad command
-Y or N question ? right click on screen mean "No" hit enter or space button mean "Yes" .
- lisp must remember last entries when start it agine
You are the only one who has courage.
You are left with the finishing touches
Edited by Abdulellah
Roy_043 It is absolutely essential to handle the OSMODE setting when using command calls.
It is not. Depends on the situation as I say I have been programming for over 40 years and know when  I need to use osmode. Know about a few other Gotcha that Autocad does to code as well.
  • Thanks 1
Give This a try
(defun c:plhook ( / plent pt1 pt2 pt3 x pt5 add ang1 ang2)
    (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))))
    (setq add 0.03)
    ;; (setq add (getreal "Enter distance to add on"))
    (setq pt5 (polar pt1 (+ (* 0.25 pi) ang1) add)) ; 135 degrees
    (if (null *mr1) (setq *mr1 "No"))
    (initget 0 "Yes No")
    (if (setq tmp (getkword (strcat "\nIs Hook direction OK? [Yes/No] <" *mr1 ">: "))) (setq *mr1 tmp))
;    (setq ans (getstring "is line ok Y or N")) ; is it in correct direction
    (if (= "Yes" *mr1) ; y or Y
      (princ "ok")
      (command "mirror" "Last" "" pt1 pt2 "Y") ; flip line
    (setq pt5 (polar pt4 (+ (* 0.25 pi) ang2) add)) ; other end
    (if (null *mr2) (setq *mr2 "No"))
    (if (setq tmp (getkword (strcat "\nIs Hook direction OK? [Yes/No] <" *mr2 ">: "))) (setq *mr2 tmp))
    ;(setq ans (getstring "is line ok Y or N"))
    (if (= "Yes" *mr2)
      (princ "ok")
3 hours ago, asos2000 said:
Give This a try
    (setq add 0.03)
      (princ "ok")
    (if (= "Yes" *mr2)
      (princ "ok")
glad to see your post , ..............what about hook length value option ?
6 hours ago, BIGAL said:
asos2000 just change the dcl version for the yes no part I have tried to get Aubdlellah to have a go himself.
Yes BIGAL me too wan that to change by himself but step by step
Fist applying his requirements
Then ask him to do a step
Then gide him to www.afralisp.net
Then he will be a member of the programming community.
  • Thanks 1
