Voltage drop calculator lisp - help
Hi every one,
I am jonir an electrical engineer. I have a small idea that I like to implement .. I need a lot to calculate the length of a polyline or line that represents In my work the power consumtion next step, I calculate how meny loads on it on exel sheet and then the output is the value of the voltage drop by this equation ( 24 -  I*(R/Length)* Length from drawing)
24 :   Constant voltege
I : sumition carrunt from different loads I choose it.
R/Length : constant
L: length of line or polyline from drawing.
  Is that possible by lisp?
Best regards,
  • CADTutor changed the title to Voltage drop calculator lisp - help
Polyline Length as what Metres, Millimetres, Feet, Inches ....?
Do you want the lisp to calculate the voltage drop? If so please provide the R/Length Constant or do you want the lisp to prompt for this as well as I ?
If you just want the polyline length in the current units then try this
(defun c:plen ( / sel ent)
  (while (setq sel (entsel "\nSelect Polyline : "))
    (setq ent (car sel))
    (alert (strcat "Polyline Length : " (rtos (vlax-curve-getdistatpoint ent (vlax-curve-getendpoint ent)) 2 3)))
  );end_while
);end_defun
  );end_while
);end_defun
Thanks for your reply.
Polyline in Millimetres, yes I need Calc. Voltege drop in cad, by select Polyline and item on it(like 2 lamps, 3 kitchen machines and 5 TV), Evry item have current like :
Lamp: 1 Ampir
Kitchin machine : 5.5 Ampir
Tv: 0.25 ampir
R/length= 0.015
The voltage drop calculation like that:
 polyline length (from cad) *    ( no. Lamps + no. Kitchen machines + no. TV)
  Is it difficult?
For Mr. Dlanor...
If you have closed curves, sometimes end point can be equal as start point... Thus, I would avoid your syntax you used and instead use more reliable classic approach via parameters :
(vlax-curve-getdistatparam curve (vlax-curve-getendparam curve))
Regards, M.R.
Lamp: 1 Ampir
Tv: 0.25 ampir
R/length= 0.015
  Is it difficult?
No, not difficult.
Do you need to enter individual appliances etc, or are you going to select blocks etc; in which case I would need a full list including loads.
Please clear me as per your data
Total current will be
Lamps 2 * 1 = 2 amp
Kitchen  3 * 5.5 = 16.5 amp
Tv  5 * 0.25 = 1.25
Total current 2 + 16.5 + 1.25 = 19.75
coefficient = 0.015
Then
Volt drop will be = total current * length * coefficient
I think that cable length shall be in meters.
Or please give me such formula source
Edited by devitg
check
As a start try this. It will accept LWPolylines 2dPolylines and Lines. The lisp checks the "insunits" system variable and converts polyline lengths to metres. You are then asked to supply the number of items for each of  "HEATER" "LAMP" "MOTOR" "SOCKET" & "TV" to calculate the total load. The default for each is 0 (zero) so a return will automatically default to this. If no polyline/Line is selected the lisp ends.
(defun c:vdrop ( / *error* sv_lst sv_vals a_lst RL I iu cu sv itxt load ipart sel obj p_len ld vd len)
  (defun *error* ( msg )
    (mapcar 'setvar sv_lst sv_vals)
    (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error : ( " msg " ) occurred.")))
  );end_*error*_defun
  (setq sv_lst (list 'osmode 'cmdecho 'dimzin)
        sv_vals (mapcar 'getvar sv_lst)
        a_lst '(("HEATER" . 8.3) ("LAMP" . 4.5) ("MOTOR" . 10.06) ("SOCKET" . 5.11) ("TV" . 3.2))
        sv 24.0
        RL 0.015
        I 0.0
        iu (getvar 'insunits)
  );end_setq
  (mapcar 'setvar sv_lst (list 0 0 8))
  (cond ( (= iu 4) (setq cu 1000.0))
        ( (= iu 5) (setq cu 100.0))
        ( (= iu 6) (setq cu 1.0))
  );end_cond
  (foreach itm a_lst
    (initget 4)
    (setq itxt (car itm)
          load (cdr itm)
          ipart (cond ( (getint (strcat "\nEnter Number of " itxt " <0> : "))) (0))
    );end_setq
    (if (> ipart 0.0) (setq I (+ I (* ipart load))))
  );end_foreach
    (setq obj (vlax-ename->vla-object (car sel)))
    (if (vl-position (vlax-get obj 'objectname) (list "AcDbPolyline" "AcDb2dPolyline" "AcDbLine"))
      (setq p_len (vlax-get obj 'length))
      (alert "NOT a Polyline/Line")
    );end_if
  );end_while
  (cond (p_len
          (setq ld (- sv (setq vd (* RL I (setq len (/ p_len cu))))))
          (alert (strcat "Constant Voltage      : " (rtos sv 2 0) "\n\n"
                         "Polyline Length (m)   : " (rtos len 2 3) "\n\n"
                         "Total Voltage Drop    : " (rtos vd 2 6) "\n\n"
                         "Voltage @ Last Device : " (rtos ld 2 6)
                 );end_strcat
          );end_alert
  );end_cond
);end_defun
Can do this add more items, Dlanorh then use your list of power items to work out load.
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm (list "Enter Qty" "Lamp      " 5 4 "0" "Heater" 5 4 "0" "Socket"5 4 "0" "TV" 5 4 "0" "Oven"5 4 "0" "Aircon" 5 4 "0" )))
(setq pload 0.0)
(setq pload (+ (* (atof (nth 0 ans)) 8.3) pload))
(setq pload (+ (* (atof (nth 1 ans)) 5.11) pload))
(setq pload (+ (* (atof (nth 2 ans)) 3.2) pload))
(setq pload (+ (* (atof (nth 3 ans)) 8.0) pload))
(setq pload (+ (* (atof (nth 4 ans)) 8.0) pload))
(alert (strcat "Power load is " (rtos pload 2 1)))
image.png.21401aee3e67cbc8d0d6ab38602c2d22.pngimage.png.3a3ab74b4922b9e04ed5c5f0d22ce5e5.png
11 hours ago, marko_ribar said:
For Mr. Dlanor...
Regards, M.R.
Hi Marko, I would agree with the above if it wasn't an electrical circuit. However IF there is a closed polyline, the power drop at the end would be the same as at the start, and the max drop, in theory, would be at the mid point.
Edited by dlanorh
(setq pload 0.0)
Hi Al. I don't have "Multi Getvals.lsp" on my laptop. Can you attach?
Its in the download section as well as a radio buttons and toggle buttons. Working on a "image multi getvals" as well as a Vector version as image is a slide which quality and image creation can be a problem. There are example calling code in the lisp. Basically the screen size is the limitation I add a double space when only a few lines.
Multi GETVALS Img.lsp
Edited by BIGAL
  • Like 2
Hi Mr. BIGAL,
I really appreciate your work , but i can't find (alantest.dcl) , the lisp didn't work .
  );end_*error*_defun
        sv 24.0
        RL 0.015
        I 0.0
  );end_setq
  );end_cond
  (foreach itm a_lst
    (initget 4)
          load (cdr itm)
    );end_setq
  );end_foreach
    );end_if
  );end_while
  (cond (p_len
                 );end_strcat
          );end_alert
  );end_cond
);end_defun
Hi Mr. dlanorh,
amazing ^_^ , I really appreciate your work , that nearest idea for my work, Can add more length ? the device located in more places on same wire ( polyline ).
 for Example TV it is in your bed room , 5 m from Plug and another TV in leving room 10 m from Plug , two pluges have same wire strat from panel to first Plug 5m Then, 10 m between to pluges , the wire is 15 m in total lenght ( 1st tv after 5m and 2nd tv 10m ).
1 hour ago, Eslam mansour said:
Hi Mr. dlanorh,
Can you post another example drawing saved in AutoCAD 2010 format as I am unable to open the attached drawing above
here you are ^_^
Drawing2.dwg
Edited by Eslam mansour
Hi BigAl, please clear me , what extension shall be the image sent to
AH:getvalsimg
(setq img_name (getfiled "select img " "" "???" 8))
I try with a ICON from ICONS  ACAD folder.
Edited by devitg
add
