AUTOSLIP Posted October 16, 2020 Share Posted October 16, 2020 Hello, I'm searching to make a LISP, to change the layer of an attribute. Actually it in "TopoAlt" Layer, I like to change in "0" layer (or other) I thinked about DXF code but i don't find it with dumpallproperties. "Battman" command would be a good solution but I can't make script "-eattedit" command is pretty close but I'm stopped when It need " attribute selection". If i could scripting "-eattedit" with an automatic attribute selection (like an already made SSGET), I could change the layer, or other properties ! Any Idea ? Quote Link to comment Share on other sites More sharing options...
John Green Posted March 11, 2021 Share Posted March 11, 2021 Did anyone ever respond to you question? I am trying do a similar operation, I have a lisp routine which convers a polyline into a block with 3 attributes, SpaceID, Area, and BlockHandle which are all on one layer for the blocks and attibutes. The routine works fine, but I now need to change the layer of both SpaceID and Area on to two different layers called Spaces and SAreas. I can work out how to change just the layer of the attributes. I know it can be done as I can do it via selecting block and changing layer manually. I am just looking for a bit of lisp which will change the layer of the attributes after block is created Quote Link to comment Share on other sites More sharing options...
