BIGAL Posted February 27, 2024 Posted February 27, 2024 (edited) Getting somewhere, thanks to Virgil at Bricscad forum. There seems not to be much information on this topic. I could find a few articles (not all in english) with some references about how to connect from Calc to Autocad, using StarBasic. https://forums.autodesk.com/t5/vba/interconnection-between-autocad-and-libreoffice-calc-via-vba/td-p/9734036 https://cadxp.com/topic/43274-connection-libre-office-calc-et-autocad/ https://www.redchar.net/pages/?x=libreoffice-scrivere-dwg Regarding the reverse connection, I could only find this old forum post, but there is nothing specific. https://forum.bricsys.com/discussion/21458/libreoffice-calc-link-to-bricscad Lots of good code to look at can run VBA code from Lisp, but will probably look at convert the VBA to lisp. I guess may have to bite the bullet and down load Libreoffice calc if to go any further. Bit busy at moment, may just do some try to open code. definitely look at Creating DWG files with LibreOffice and progeCAD - Roberto Rossi (redchar.net) try the sample file, let me know how it goes. Edited February 27, 2024 by BIGAL Quote
SLW210 Posted February 28, 2024 Posted February 28, 2024 I really don't see doing this at the LISP level. Really need to just use LISPs for generic text files and bypass Calc, IMHO. I looked at all of this a while ago, seems no major changes since then. LibreOffice also is not compatible with Microsoft VBA, it has it's own language, a version of BASIC. LibreOffice BASIC Programming Guide - The Document Foundation Wiki Quote Note: VBA : Compatibility between LibreOffice Basic and VBA relates to the LibreOffice Basic language as well as the runtime library. The LibreOffice API and the Dialog Editor are not compatible with VBA (standardizing these interfaces would have made many of the concepts provided in LibreOffice impossible). Import MS-Word Macros - English - Ask LibreOffice Quote
Truski Posted February 28, 2024 Author Posted February 28, 2024 I don't want to waste any more of your time with this Thank you very much for everything... Quote
SLW210 Posted February 28, 2024 Posted February 28, 2024 I wish I had more time to play with this. I do know Python can access Libre Office Calc and AutoCAD, not sure if you can do what you want with it. Python Scripts (libreoffice.org) Python : Programming with Python (libreoffice.org) Creating Python Scripts with ScriptForge (libreoffice.org) Quote
SLW210 Posted February 28, 2024 Posted February 28, 2024 I did find a resource on LibreOffice macros and there is a lot for using Python. I think I need to download PyCharm, I'll have to see, I might have it. If interested in going with non-LISP solutions. OpenOffice.org Macro Information By Andrew Pitonyak Quote
BIGAL Posted February 29, 2024 Posted February 29, 2024 (edited) Well this works for put cells try this using VBA in Acad or Bricscad. Opens a blank document and puts some values so a big success. Sub Main() 'VARIABLES: Dim obL_Service_Manager As Object Dim obL_Core_Reflection As Object Dim obL_Desktop As Object Dim srL_Url As String Dim obL_Calc_Document As Object Dim obL_Sheet As Object Dim obL_Range_First_Column As Object Dim obL_Range_ToSort As Object Dim a1L_Arguments() Dim lnL_iLast_Row As Long Dim lnL_iLast_Column As Long 'PROCESS: Set obL_Service_Manager = CreateObject("com.sun.star.ServiceManager") Set obL_Core_Reflection = obL_Service_Manager.createInstance("com.sun.star.reflection.CoreReflection") Set obL_Desktop = obL_Service_Manager.createInstance("com.sun.star.frame.Desktop") srL_Url = "private:factory/scalc" Set obL_Calc_Document = obL_Desktop.loadComponentFromURL(srL_Url, "_blank", 0, a1L_Arguments) Set obL_Sheet = obL_Calc_Document.Sheets.getByIndex(0) obL_Sheet.getCellRangeByName("A1").String = "PAPERINO" obL_Sheet.getCellRangeByName("C6").Value = 200 obL_Sheet.getCellRangeByName("C7").Value = 100 End Sub I did down load Libre office only way to work out anything. Next step is open a known Ods file. See srl = Edited February 29, 2024 by BIGAL Quote
SLW210 Posted February 29, 2024 Posted February 29, 2024 No LibreOffice at work, maybe tonight I will have time at home. I am still reading through all of the information I have linked here. One of those sites has a link to a Sun Microsystems StarOffice programming guide which OpenOffice and LibreOffice is from the source code that was released, that's why all of (com.sun.star.) references. From what I have found on StarOffice, they had a Macro Converter for converting Microsoft Office VBA macros to StarOffice Basic. I am not sure if it was ever open sourced. There is an online converter, not sure how well it works... Excel VBA to OpenOffice Basic Converter Here is a PDF on converting VBA to StarBasic from OpenOffice VbaStarBasicXref.pdf I also found that adding option vbasupport 1 to the top of VBA code will work in some cases (newer releases). Quote
SLW210 Posted February 29, 2024 Posted February 29, 2024 I would still like to see a before and after example of what exactly is being modified. There still may be a better method to get this done. Quote
Truski Posted February 29, 2024 Author Posted February 29, 2024 Here I sent a sample of what it looks like before and after On 2/9/2024 at 9:34 AM, Truski said: Hi SLW210, I am familiar with the Batch Attribute Editor application from LEE MAC. It works very well but in my case not all attributes are the same, so I can't use that application. TEST.7z 1.98 MB · 3 downloads Quote
BIGAL Posted February 29, 2024 Posted February 29, 2024 (edited) I amended the test code, removed the call to last row etc. If you go into VBAMAN and make a DVB can load it. Or do this, it should open a Calc sheet. The paperino is a string and the numbers are just that. (vl-vbaload "D:\\Acadtemp\\Libre\\test1.dvb") (vl-vbarun "Test1") Test1.dvb Edited February 29, 2024 by BIGAL Quote
BIGAL Posted February 29, 2024 Posted February 29, 2024 Truski, next step is to work out how to do for multiple dwgs but only maintain 1 Libreoffice calc. Even with lisp this is not an easy task, simplest way is to use a script and make a csv file. Just google and you will find many examples. I will continue to play with Libreoffice calc and try to convert to VL. Quote
SLW210 Posted August 19, 2024 Posted August 19, 2024 I haven't tested this since no LibreOffice at work. I'll take it home and if I find time at home check on it. I started with this one by fixo, I'll check on others if it works... ;;; Extract block count information from AutoCAD and exporting it to an LibreOffice Calc file. | ;;; | ;;; https://www.cadtutor.net/forum/topic/79565-autocad-use-libreoffice-instead-of-excel/ | ;;; | ;;; By SLW210 (Steve Wilson) | ;;;________________________________________________________________________________________________________________________________________| ;;; | ;;; Original- August 7th, 2024 | ;;; | ;;;________________________________________________________________________________________________________________________________________| ;;; | ;;; Adapted the original LISP code to work with LibreOffice instead of Excel, I used LibreOffice's COM API, which is similar to Excel's | ;;; but with some differences in method names and object handling. (I put the internet to good use for this.) | ;;;////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////| ;;; | ;;; Thanks to all of the people on various LibreOffice, OpenOffice, StarOffice by Sun Microsystems (original source code) | ;;; and related content forums including some AutoCAD related Forums, mostly CADTutor.net and BIGAL. | ;;;________________________________________________________________________________________________________________________________________| ;;; Originally BCEX.lsp modified to work with LibreOffice Calc (LOC). | ;;;________________________________________________________________________________________________________________________________________| ;;;***********************************************************Original header**************************************************************| ;;; | ;;; From man to man | ;;; | ;;; written by Fatty 2005 All rights removed | ;;; | ;;; helper function | ;;; | ;;; group list into separate sublists | ;;; | ;;;****************************************************************************************************************************************| (defun group-by-first (lst / ret tmp) (while (car lst) (setq tmp (list (vl-remove-if-not (function (lambda (a) (eq a (car lst)) ) ) lst ) ) ) (setq ret (cons (car tmp) ret)) (setq lst (vl-remove-if (function (lambda (a) (eq a (car lst)) ) ) lst ) ) (setq tmp nil) ) (setq ret (mapcar (function (lambda (x) (list (car x) (length x)) ) ) (reverse ret) ) ) ) (defun C:BCEX_LOC (/ acsp adoc aoffice adoc adoc_path aoffice_path all_data awb blk_lst bname bnm brds cll clls colm cols com_lst csht data data_list datum en filt fnt header_list i intr nwb rang row scol sht srow ss ) (vl-load-com) ;; Initialize LibreOffice (setq aoffice (vlax-get-or-create-object "com.sun.star.ServiceManager") ) (setq adoc (vlax-invoke-method aoffice 'createInstance "com.sun.star.frame.Desktop" ) ) (setq adoc (vlax-invoke-method adoc 'loadComponentFromURL "file:///" "private:factory/swriter" :vlax-false :vlax-false nil nil ) ) (setq aoffice_path (vlax-get-property adoc 'URL)) (setq adoc_path (vl-string-left-trim "file://" aoffice_path)) ;; Initialize other variables (setq blk_lst nil data nil com_lst nil ) ;; Prompt for block name (setq bname (getstring T "\nEnter a block name (case-sensitive) <*> : \n" ) ) ; press enter to count all blocks (if (eq bname "") (setq bname "*") ) ; change to default block name (setq filt (list (cons 0 "INSERT") (cons 2 bname) (cons 410 (getvar 'ctab)) ) ) (if (setq ss (ssget "_X" filt)) (progn (setq i -1) (repeat (sslength ss) (setq en (ssname ss (setq i (1+ i)))) (setq bnm (vla-get-effectivename (vlax-ename->vla-object en))) (setq blk_lst (cons bnm blk_lst)) ) (setq com_lst (group-by-first blk_lst)) (vlax-for blkdef (vla-get-blocks adoc) (foreach record com_lst (if (eq (vla-get-name blkdef) (car record)) (setq com_lst (subst (append record (list (vla-get-comments blkdef))) record com_lst ) ) ) ) ) (setq data (append (append (list (list "Layout" (getvar 'ctab))) com_lst) ) data (append data (list (list "Subtotal : " (length blk_lst)))) all_data (cons data all_data) blk_lst nil com_lst nil data nil ) ) ) ;; Prepare data for LibreOffice (setq all_data (apply 'append (reverse all_data))) ;; Initialize LibreOffice Writer (setq aoffice (vlax-get-or-create-object "com.sun.star.ServiceManager") ) (setq adoc (vlax-invoke-method aoffice 'createInstance "com.sun.star.frame.Desktop" ) ) (setq adoc (vlax-invoke-method adoc 'loadComponentFromURL (strcat "file:///" adoc_path) "private:factory/swriter" :vlax-false :vlax-false nil nil ) ) (setq csht (vlax-get-property adoc 'Sheets)) (setq sht (vlax-get-property csht 'Item '1)) ;; Set up header (setq header_list '("Name" "Quantity" "Description")) (setq cols (length header_list)) (setq row 1 colm 1 ) (vlax-put-property (vlax-get-property sht 'Text) 'String "Block Count Info" ) ;; Write header to LibreOffice (repeat (length header_list) (vlax-put-property (vlax-get-property sht 'Text) 'String (car header_list) ) (setq colm (1+ colm) header_list (cdr header_list) ) ) ;; Merge header cells (setq srow "A1" scol (strcat (chr (1- (+ (ascii "A") cols))) "1") ) (vlax-invoke-method (vlax-get-property sht 'Range) 'Merge) (vlax-put-property (vlax-get-property (vlax-get-property sht 'Range) 'Text) 'HorizontalAlignment 2 ) ; center alignment ;; Fill cells with data (setq row (1+ row) colm 1 ) (repeat (length data_list) (setq datum (car data_list)) (repeat (length datum) (vlax-put-property (vlax-get-property sht 'Text) 'String (car datum) ) (setq datum (cdr datum)) (setq colm (1+ colm)) ) (setq colm 1 row (1+ row) ) (setq data_list (cdr data_list)) ) ;; Draw borders and change font (setq clls (vlax-get-property (vlax-get-property sht 'Range) 'Cells)) (setq brds (vlax-get-property clls 'Borders)) (vlax-put-property brds 'LineStyle 1) (setq fnt (vlax-get-property (vlax-get-property sht 'Range) 'Font)) (vlax-put-property fnt 'Italic 1) (vlax-put-property fnt 'Size 10) ;; Autofit columns (vlax-invoke-method (vlax-get-property sht 'Range) 'Columns 'AutoFit ) ;; Save LibreOffice document (vlax-invoke-method adoc 'StoreToURL (strcat "file:///" adoc_path) (vlax-make-variant nil) ) ;; Clean up (vlax-release-object cll) (vlax-release-object rang) (vlax-release-object csht) (vlax-release-object sht) (vlax-release-object nwb) (vlax-release-object awb) (vlax-release-object aoffice) (princ) ) (prompt "\n\t\t***\tBlock count info to LibreOffice program is loaded\t***\n" ) (prompt "\n\t\t***\tType BCEX_LOC to execute\t***\n") (princ) Quote
SLW210 Posted August 19, 2024 Posted August 19, 2024 Not working on my 2000i at home. ; error: Automation Error. [automation bridge] Too many parameters New version still gets ; error: Automation Error. [automation bridge] Too many parameters after some tweaks. I'll get back on this when I get more time. Quote
BIGAL Posted February 4, 2025 Posted February 4, 2025 (edited) I have started again with this and started making defuns for each type of task. A start, making defuns rather than just code. See updated code below Edited February 8, 2025 by BIGAL 2 Quote
BIGAL Posted February 7, 2025 Posted February 7, 2025 Added some more defuns, stuck on get a range of cells can use a double loop read rows and columns but should be able to read a range. Hope to post something soon. Quote
GLAVCVS Posted February 8, 2025 Posted February 8, 2025 Hi @BIGAL I'm trying to test your functions but I'm not sure how to go about it. I've had some errors while running them, probably my fault. Can you attach an example of how to get a record and another of how to write it? Thanks in advance Quote
BIGAL Posted February 8, 2025 Posted February 8, 2025 (edited) I have updated the code getting a range of cells as a list, here is a how to use. If I have done it correctly, just appload the saved lisp file. This way all the defuns are ready to use. Ok you need to Open Libre Calc and save a "Blank" ODS file. Also edit this section of code and save the lisp. You should be ready then to start using. (if (= ans "1") (setq FileName "D:\\acadtemp\\blank.ods") (setq filename (getfiled "ODS or XLS" "d:\\" "ods,xls" 16)) ) Do (openlibre) it should open Blank or your chosen ODS. PLEASE NOTE A1= 0 0 Excel is 1 1 You can get a cell using (libgetcell '(col row)) You can put a cell using (libputcell '(crange) val) crange again '(col row) You can get a range of cells into a list (libgetrange "(col1 row1 col2 row2)) I am working on that right now, have some help from Tim_n via Bricscad forum. Hope this helps. See page 4 for latest Version. Edited February 10, 2025 by BIGAL Quote
GLAVCVS Posted February 9, 2025 Posted February 9, 2025 Have you also tried this code in AutoCAD? Quote
GLAVCVS Posted February 9, 2025 Posted February 9, 2025 (edited) I have a feeling this won't work in AutoCAD Edited February 9, 2025 by GLAVCVS Quote
GLAVCVS Posted February 9, 2025 Posted February 9, 2025 (edited) If this is so, there is still another possibility.... Does anyone know how to find out the structure of these .ods files? Edited February 9, 2025 by GLAVCVS Quote
