Somehow a setting was changed on my Autocad and now every time I draw or move an object it leaves these pink X's. The X's are made up of 2 sets of 3 lines intersecting. The X's are also different sizes. How do I turn these off??
  • Replies 39
  • ReMark
    10
  • bean
    10
  • xenspidey
    5
  • JoeC
    2
nope that didn't work either. hmm
thanks for the help.
Can you erase these Xs? If so, then I think you need to change your PDMODE to zero.
the x's are not erasable nor can you snap, grab, or move them. i changed the pdmode to 0 but that didn't change anything either.
Definitely mystery Xs! Do they disappear when you regen?
my S.W.A.G. is LIGHTGLYPHDISPLAY, set that to 0
check out this printscreen of what i'm looking at:
picasaweb.google.com/shellyabrown/Autocad#
that...that is odd. I don't believe I'e eer seen any markers like that produced by AutoCAD before. Do you have any third party software (add-ons, etc.) installed?
I've been there.
I believe those are most likely empty text entities.
Set "qtextmode" to 1 and see if they turn into rectangles. If they do, you should be able to pick and erase.
If this doesn't do, zoom out, select all ("select" "all"), and remove everything you can see that you want, leaving the area of these mystery entities. You should then be able to "erase" "p" (for previous) and they should be gone.
Purge drawing.
Is there a Defpoints layer?
Are we actually talking plain AC 07 and not some vertical product?
just tried the qtext mode and that didn't work. this is a valid AC 2007 version. i work in an office that buys real versions so i don't think i have any add-ons or anything like that. they started appearing about 3 weeks ago when i opened a drawing that was not ours or really old. and the X's started to appear when i draw lines or move stuff around. i purged because i thought it was just in one drawing but it's in every drawing i open. the weird part is the x's don't really relate to any endpoint or midpoint of any object. it seems to have a completely random placement. i'm going to keep trying other things to see what happens.
What happens if you Wblock the entities to a new file? Does the problem persist?
Do you have the "Node" box checked in the "Object Snap Mode" in the "Settings" dialogue box?
answers to your questions: they do not plot. just tried wblock- if i select just the x's they do not qualify as objects. and i unchecked the node box in osnap and it's still there.
haha this is hilarious.
thanks again for all your suggestions. these are truly mystery x's. :)
Sorry for the misunderstanding, the "Node" box needs to be checked.
oh yeah, it was checked before i unchecked it so i assume that was not it. plus i tried a bunch of snap settings before
