HypnoS Posted 6 hours ago Posted 6 hours ago Hi all, I was wondering if someone could help me with a lisp modyfication. I need to modify CopyBlockStoCurve lisp so I don't need to select each block individually co copy it to the curve. I thought why not copy a function from numpol, which numbers blocks according to a polyline. So I need the new CopyBlockStoCurve to arrange blocks on a curve, but in accordance with how the blocks are positioned on another polyline basiclly. Can anyone help? numpol.lspCopyBlocksToCurve.lsp Quote
SLW210 Posted 4 hours ago Posted 4 hours ago That's not a drawing, just images. I don't see a curve. Is the text part of the block? Really need the drawing. Quote
HypnoS Posted 4 hours ago Author Posted 4 hours ago okay so these are dynamic blocks with attributes, thats why i use numpol to change attribute values acording to polyline i drew over them. Now I want to use something like copyblockstocurve (wich works also with polylines) to align my blocks to new straight line in the same order numpol did the numering. So that I could use them to draw a scheme. Example.dwg Quote
