BIGAL Posted July 25 Posted July 25 (setq plent (entsel "\nPick pline near end "))) (setq pt (cadr plent)) (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))) (setq obj (vlax-ename->vla-object plent)) (setq pt1 (vlax-curve-getstartPoint obj)) (setq pt2 (vlax-curve-getendPoint obj)) (setq d1 (distance pt pt1)) (setq d2 (distance pt pt2)) (if (> d1 d2)d (setq co-ord (reverse co-ord)) ) To reverse direction of a line or pline, "It is a task that takes 5 seconds." No its instant. Quote
HypnoS Posted Friday at 08:04 AM Author Posted Friday at 08:04 AM TBH devito code meets my needs, for what i send big thanks once more. One thing I'd like to be added is to let me change distance between blocks Quote
SLW210 Posted Friday at 10:37 AM Posted Friday at 10:37 AM 2 hours ago, HypnoS said: TBH devito code meets my needs, for what i send big thanks once more. One thing I'd like to be added is to let me change distance between blocks Did you bother to try my code? It asks for a line and distance between blocks. Quote
HypnoS Posted Friday at 11:44 AM Author Posted Friday at 11:44 AM @SLW210 I tried yours but I cant get it to work, I think Im missing something. "Enter the tag to use" What tag am I supposed to type in? Attribute name or value does not work. Quote
devitg Posted Friday at 02:08 PM Posted Friday at 02:08 PM 6 hours ago, HypnoS said: TBH devito code meets my needs, for what i send big thanks once more. One thing I'd like to be added is to let me change distance between blocks It ask you to set such distance Or you mean to set distance for each block at the straight line? Quote
SLW210 Posted Friday at 08:38 PM Posted Friday at 08:38 PM 8 hours ago, HypnoS said: @SLW210 I tried yours but I cant get it to work, I think Im missing something. "Enter the tag to use" What tag am I supposed to type in? Attribute name or value does not work. The actual TAG name, in the drawing you posted it is ADRES Quote
HypnoS Posted yesterday at 07:41 AM Author Posted yesterday at 07:41 AM @devitgYeh! Distance between blocks on a new straight polly. @SLW210Sorry but typing block atribute or even clicling on it seems to no work for me Enter the tag to use: ADRES ; error: bad argument type: numberp: --- Quote
SLW210 Posted yesterday at 11:06 AM Posted yesterday at 11:06 AM I'll look into that, I might have posted the wrong one. I was working on one to just use the block clicked assuming a single attribute. Quote
devitg Posted yesterday at 02:56 PM Posted yesterday at 02:56 PM On 7/24/2025 at 1:26 PM, HypnoS said: Yours works great. the only thing I would like to add is to set a distance between blocks on the line, just like the copyblockstocurve has. @HypnoS Find attached cpy-blk-2-poly-01.lsp Quote
HypnoS Posted 7 hours ago Author Posted 7 hours ago @devitgcode acts weird. It asks me to type distance,and when I do it places only one block and asks for distance again to pace another block, and on and on. Quote
SLW210 Posted 5 hours ago Posted 5 hours ago My code only gives that error if there are letters in the ATTRIBUTE, works no errors on the drawing you posted. Maybe you should post an actual drawing that you are using this on. Even the images you posted are different by a lot from the drawing you posted. Quote
HypnoS Posted 4 hours ago Author Posted 4 hours ago well I hoped for this lisp to work with any blocks with attributes. here are the same b locks Im using. example [2].dwg Quote
SLW210 Posted 4 hours ago Posted 4 hours ago There has to some consistency in what's being sorted. Will there always be just one attribute? Quote
HypnoS Posted 3 hours ago Author Posted 3 hours ago Now that I think about it... let's assume there will be multiple attributes. Quote
devitg Posted 1 hour ago Posted 1 hour ago (edited) 5 hours ago, HypnoS said: @devitgcode acts weird. It asks me to type distance,and when I do it places only one block and asks for distance again to pace another block, and on and on. @HypnoS use the previous, reattached, It will ask for distance only once , and ask for the straight line start point to paste each block cpy-blk-2-poly.lsp copy block 2 poly 2025-08-05 10-37-41.rar Edited 1 hour ago by devitg add info Quote
