Hi all,
I have an idea for an AutoCAD lisp, but I don't know if it's possible. I'd like to get a sanity check before I attempt creating it! The process I'm thinking of is as follows;
1. Iterate through a number of blocks in the .dwg (blocks are always in model space)
2. For each block grab an attribute value held within the block (FIN-B / FIN-C) in the example dwg - This data will be entered manually for each block
3. Search for this "value" in an external excel file (prompt user to pick a file) - The value will always be in Column A
4. Copy the information held in the three relevant cells (Column B - the the same row and the next two rows below) back into the block (FIN-LINE-1 / 2 / 3)
5. Repeat this process until all named blocks are populated (theExcel.xlsxre are 10 blocks maximum)
I don't mind if I have to change the formatting a little etc. But I'd just like to know if this would actually be possible or if I will hit a barrier that will prevent it from working. Could anyone please tell me if this is possible or would it be a waste of time to try?
I've attached an example .dwg and excel file for reference.
Thank you in advance for any help.
Cad Blocks.dwg
Yes, this is possible; though, you'll find it easier using a .csv/.txt file (which can be read using standard AutoLISP IO functions), in lieu of an .xls/.xlsx file (for which you'll need to use ActiveX(COM) to interface with the installed Excel application). Once the data has been acquired however, updating the block attributes is straightforward.
@Lee Mac
Ok fantastic that's great news thank you. The problem is that this data will ALWAYS be held and monitored in an excel spreadsheet. The company uses this method as a standard and it will never change, I'm trying to gather the data without changing any procedures as this would invoke carnage.
I've got the code to read from and write to the blocks working fine. As the next step, I'm trying to simply read a cell value from Excel, but it keeps throwing "error: bad argument type: VLA-OBJECT nil" and I don't have the experience to figure out why (I'm new to LISP). This is the code I have. Are you able to give me a nudge in the right direction? Or provide some sample code that will let me read a cell value?
Many thanks;
(defun c:FindExcelValue ( / fname xlApp xlBook xlSheet searchStr foundVal row col cellVal)
  ;; Prompt for Excel file path
  (setq fname (getfiled "Select Excel file" "" "xls;xlsx" 0))
  (if fname
      ;; Ask for search string
      (setq searchStr (getstring T "\nEnter string to search for: "))
      ;; Start Excel
      (setq xlApp (vlax-get-or-create-object "Excel.Application"))
      (setq xlBook (vlax-invoke-method (vlax-get-property xlApp 'Workbooks) 'Open fname))
      (setq xlSheet (vlax-get-property xlBook 'ActiveSheet))
      ;; Assume search in column A (col = 1)
      (setq row 1
            col 1
            foundVal nil)
      ;; Loop until empty cell
      (while (and (not foundVal)
                  (setq cellVal (vlax-get-property (vlax-get-property xlSheet 'Cells) 'Item row col))
                  (/= (vlax-get-property cellVal 'Value) nil))
        (if (= (strcase (vlax-get-property cellVal 'Value)) (strcase searchStr))
          (setq foundVal (vlax-get-property (vlax-get-property xlSheet 'Cells) 'Item row (1+ col)) 'Value))
        (setq row (1+ row))
      ;; Print result
      (if foundVal
        (princ (strcat "\nFound value: " (vl-princ-to-string foundVal)))
        (princ "\nString not found.")
      ;; Clean up
      (vlax-invoke-method xlBook 'Close :vlax-false)
      (vlax-release-object xlSheet)
      (vlax-release-object xlBook)
      (vlax-release-object xlApp)
BigAl is pretty good with Excel - got to wait for him to wake up - he's got some stuff stashed away that might also do the trick, also look in 'downloads' at the top here, Alan Excel might do what you want with the excel part.
@Danielm103
Thank you for this, it looks really good. The problem is that I'm building this for people that are exceptionally resistant to change, and really I need a standalone lisp that can just be launched from within autocad and handles everything. If there is any more complexity to it than that, then it simply wont even be considered for adoption :(
@Steven P
Thanks for the info, I'll take a look this evening once I've got my actual work out of the way for the day
Edited by swanny89
I have access to AutoCAD 2025 and AutoCAD LT 2025, however I'm trying to build it in a manner where it functions in LT as thats what most of the guys use
Might be tricker in LT - not every function works
Resistant to change... just show them it is quicker, subtle ways like doing everything and grabbing a coffee while they are still piling through it the 'old' way
Yeah, LT is a problem, you won’t have vlax-get-or-create-object,  you could probably parse .CSV files though
That's unfortunate :(
@Steven P haha if only it were this simple...Honestly I've never experienced resistance like this before!
Could a LISP in LT export the Excel data to a CSV, pull the data from that, and the delete the CSV? I'm going to assume that the answer is no due to the lack of vlax-get-or-create-object.
I think I've achieved a workaround. I'm going to set a macro within excel that exports the data to a CSV every time the excel document is saved (overwriting the existing versions). I'm then going to read this using the standard IO functions available to me in LT. It's not the cleanest solution, but I believe it should work.
If anyone has any advice regarding pitfalls etc. that I might encounter please feel free to enlighten me
Ok a  few comments,
Lets start, as mentioned when they added lisp to LT they decided to leave the smart stuff out, typical Autodesk,  so you can not talk direct to Excel, Full Acad, or Bricscad, plus I believe a few others no problem. Just a side comment can also use Libre Calc.
From Cad, yes can get range used," so get a list of all "A" column values no user input. Then find the one your looking for this will give you a row value. So put the attributes values into a cell.
I have "Alan Excel.lsp" which is a lot of defuns that do different tasks I have saved the latest version in the download section. I have acknowledged those that have helped in putting it together the extra defuns, I keep adding to it depending on task.
One thing you can do is check (setq xlApp (vlax-get-or-create-object "Excel.Application")) if it errors or returns NIL that would occur in LT. Please let me know. If its a simple nil then do the export to csv and use say (alert "Run the macro to import the csv file"), as a side note pretty sure in full version could call the macro, so one common code only.
There is one little glitch when you need to go to Excel to do something user wise you must click on Excel window, but I did find a way around it using Powershell that is called from the CAD so it auto jumps to Excel. Should be able to do same in excel jump back to cad.
Just google about your Excel macro questions there is huge amount of info out there use VBA answers and convert to Lisp sometimes.
Edited by BIGAL
8 hours ago, mhupp said:
attout and attin?
That's an Express Tool not available in AutoCAD LT.
I was going to suggest the Excel Macro method.
Maybe a Script can be used.
Was an AutoCAD LT expert around here that did all kinds of customizations, including using Excel, before LT had AutoLISP function. @steven-g IIRC.
"Was an AutoCAD LT expert" there was lisp enabler and pretty sure Autodesk legal team shut them down. It was produced way back around 2005. It was called LT-Extender. Google can find some info about it.
That's not what steven-g used, plus Autodesk shut them down.
From Danielm103's link.
Quote
The development, distribution and support of LT-Extender software has been ceased.  Torsten Moses, February, 20th 2009
They suggest BricsCAD now.
Saw this when searching for something else. can be modified for blocks attributes.
Forgot to add this idea, why not run the whole lot from a Macro in Excel ? I have make objects from Excel data in CAD, Excel does the same thing opens a link to the CAD. So please try this example it has the macro in it. Should draw a line, circle and pline.
The critical portion of code in the macro is this could be just tested on its own to open Acad. Let me know if works with LT the get Application may be a problem.
 Set acadApp = GetObject(, "AutoCAD.Application")
    If acadApp Is Nothing Then
        Set acadApp = CreateObject("AutoCAD.Application")
        acadApp.Visible = True
    End If
draw object xl acad.xlsmdraw object xl bricscad.xlsm
Edited by BIGAL
