ReMark Posted June 9, 2009 Posted June 9, 2009 Take a look at this too: http://www.wbdg.org/design/parking.php Quote
Narmin_T Posted June 9, 2009 Author Posted June 9, 2009 Remark.....Your advice seems great but here they hardley give info as easy as that. Basically the wont give it ....unless you are professional body. anyway, I am not doing too bad with the parking. Thanks a lot for the links again. Quote
ReMark Posted June 9, 2009 Posted June 9, 2009 Two books you can consult: Reinforced Concrete, Mechanics and Design, 4th ed., by James G. MacGregor and James K. Wight (check out the chapter on continuous beams and one way slabs) and Prestressed Concrete, A Fundamental Approach, 5th ed., by Edward G. Nawy (check out the chapter on flexural design of prestressed concrete elements). Both books have plenty of good details. Quote
Narmin_T Posted June 9, 2009 Author Posted June 9, 2009 Cant use reinforced concrete for this proj as its not sustainable , cant be recycled you see, I have been told regarding my design and nature of the project to use cast in place (insitue) concrete on my floor system. Have no problem for the facade as the cladding is glass (bolt fixed glazing or stick system) what partitions would you suggest for interior of the building ??? concerns are accoustic,fire rating,curved design,flexibility, and sustainablity obviuosley. tanx Quote
ReMark Posted June 9, 2009 Posted June 9, 2009 Reinforced concrete can be recycled. Look at this: http://www.concretenetwork.com/concrete/demolition/recycling_concrete.htm Quote
ReMark Posted June 9, 2009 Posted June 9, 2009 You can use spandrel glass for the interior partitions. See this: http://www.viracon.com/index.php?option=com_content&view=article&id=81&Itemid=62 Quote
ReMark Posted June 9, 2009 Posted June 9, 2009 "...they hardley give info as easy as that." I would suggest that you tell the stuffed shirts that you are a registered student (which you can prove), provide them with some details about your assignment (show them the course syllabus) and also furnish them with your professor's name and a means by which they can contact him to verify the nature of your request. Don't let someone in a tie and dress shirt put you off. They are people, just like you, engaged in a civil servant's job. They work for you and anyone else who pays taxes. Don't take "no" as an answer. Be firm, be polite and most of all be brave. They don't really bite. Those big teeth are just for show. Think of it as developing yourself as a future architect. Quote
ReMark Posted June 9, 2009 Posted June 9, 2009 Acoustical materials: http://www.acousticalsurfaces.com/ Quote
jfg Posted June 9, 2009 Posted June 9, 2009 To know what to detail, our instructor always told us to look at the plans and think which parts of the building wouldn't be built the way it should be just by looking at the plans. Then you know that area of the building needs to be detailed to make it clearer to the tradespeople. Another way to pick which elements to detail, is to look at what could be "problem" junctions. For example where the brick veneer meets metal cladding. There needs to be some precautions taken to make the enveloppe waterproof. About making your drawings look good.. I think a lot of it has to do with proper lineweight. I see a lot of different drawings and in my opinion its a big part of what makes a drawing clear or not. Quote
ReMark Posted June 9, 2009 Posted June 9, 2009 A good resource for building "green" is eco-structure. It is available in magazine form and online as well. Visit http://eco-structure.com/ for futher information. Maybe you can incorporate a vegetative roof to offset the carbon footprint of the vehicles using the facility. Quote
ReMark Posted June 9, 2009 Posted June 9, 2009 For something different consider the use of architectural grating in your design. For ideas visit www.ohiogratings.com and see what they have to offer. Quote
pattyandme Posted June 9, 2009 Posted June 9, 2009 Just my opinion but the basement layout celling would have to support the weight of the 3 floors above it in a 3 story building. so changing the support structure to another alignment post/beam would only be possable if the engineering of the 1st floor could support the other 2. thinking the posts off set from the basement posts. Quote
Eatonpcat Posted June 9, 2009 Posted June 9, 2009 Cast in place columns from Garage to first floor. Post-tensioned slab for first floor. Wood or light gage framing above. Done. Quote
Narmin_T Posted June 10, 2009 Author Posted June 10, 2009 oh ,great ....thank you all! working on it........amazing advice . Quote
ReMark Posted June 10, 2009 Posted June 10, 2009 We now expect to see a finished image upon completion. Don't disappoint us. We've all worked hard on your problem. Thanks, in advance, for sharing. Good luck. Quote
Narmin_T Posted June 10, 2009 Author Posted June 10, 2009 Hehe, yup....I keep u posted. many tanx Quote
Narmin_T Posted June 10, 2009 Author Posted June 10, 2009 back again with questions.... I am really confused with curtain wall detailing....how exactly they connect with interior partitions??? the curtain walls are bolt fixed...by the way! frameless ... Quote
Eatonpcat Posted June 10, 2009 Posted June 10, 2009 back again with questions....I am really confused with curtain wall detailing....how exactly they connect with interior partitions??? the curtain walls are bolt fixed...by the way! frameless ... This structure seems way too difficult for someone with your level of education to be designing. The questions your asking have nothing to do with Autocad... Maybe you should be in a structural engineering forum. What level of education have you completed?? Sounds like this is your first design attempt (complicated building if this is your first). I have curtain wall details, but I think maybe you should have a chat with your prof. have him/her teach you how to solve some problems on your own. Good luck though Quote
qball Posted June 10, 2009 Posted June 10, 2009 certainly sounds like the teacher is "throwing them in the deep end", or narmin spent all semester texting and not listening, and now it's crunch time. Interesting way to learn anyway. Quote
ReMark Posted June 10, 2009 Posted June 10, 2009 Sorry, can't help you with curtain wall detailing as my line of work doesn't cover such things. I'll ask a friend and coworker of mine when I get back in the office Thursday morning (he has a Masters in Civil Engineering). Best I can do. Quote
