  • 1 month later...
I made a 100 on the civil drafting assignment so i hope this helps others
Edited by cup2cake
Congratulations cup2cake on your score of 100.
  • 1 year later...
I've done everything for Sheet 2 except the Cut and Fill. I'm having a bit of a hard time of making how to draw it out to click in my brain. I've seen a lot of examples on here, and I think I'm on the right path. Any clarification or tips would be greatly appreciated. I know the instructions say that elevation 180' will be height for leveling out.
Ratio-rectangle creation.
  • 1 month later...
Hello all. Now I'm struggling with the same issues as everyone one else. So I've gotten to the cut and fill portion, and I'm stuck trying to figure out how to show this part of the instructions.
Ms. Capitano decides to keep the driveway and the house level at elevation 180. Her surveying company recommends an angle of repose of 1.5:1. Draw the driveway layout cut and fill in the lower-left corner of your drawing. Use the information listed here to show the new contours on both sides of the driveway.
How am I supposed to start off this, and how does the "angle of repose" factor in? Don't remember reading about that... Here's what my drawing looks like so far.
Thanks!
The driveway profile will look something like this.
I've seen that photo in this chat. I'm just confused about how to even start it . What is it referring to when it says for example "Station 2+20"?
Definition: "Stationing in surveying is a linear measurement system used to pinpoint exact locations along a project's baseline or centerline. One full station equals 100 feet."  It starts as 0+00 (0 feet) which in this case would be the center of the cul-de-sac and stops at the end of the project which would be station 3+78.90 (378.97 feet).  In between there is station 0+50 for the point-of-curvature (PC), station 1+93.87 for the point of tangency (PT) along with stations 1+00, 2+00, 3+00 and any others deemed necessary to call out.
Okay that makes sense. That explanation was no where in my material. So when you say to the edge of the project, where is that?
