topgunmatt Posted April 29, 2013 Share Posted April 29, 2013 Hi My Tutor has recently given me a iso drawing to complete. I think the drawing is correct but would really appreciate if either someone could check the drawing for me. Better still if someone could complete the drawing from scratch i could overlay it and see if i have made any mistakes. It not a large drawing so im sure if your good on ISO's it will be quite easy. I would really appreciate it if someone would come to my aid. Thanks Matty Quote Link to comment Share on other sites More sharing options...
tzframpton Posted April 29, 2013 Share Posted April 29, 2013 Better still if someone could complete the drawing from scratch i could overlay it and see if i have made any mistakes.Haha!! Nice try. Upload a PDF of what you got so far. Quote Link to comment Share on other sites More sharing options...
topgunmatt Posted April 29, 2013 Author Share Posted April 29, 2013 I can email you my drawing that i have completed and the pdf of what it should be if you could check for me ??? Would you do this for me please?? Regards Matt Quote Link to comment Share on other sites More sharing options...
topgunmatt Posted April 30, 2013 Author Share Posted April 30, 2013 Hi Can anyone help? Thanks Matt Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 30, 2013 Share Posted April 30, 2013 Attach a copy of the PDF to your next post. Someone here will take a look at it. Quote Link to comment Share on other sites More sharing options...
topgunmatt Posted April 30, 2013 Author Share Posted April 30, 2013 Hi My Tutor has recently given me a iso drawing to complete. I think the drawing is correct but would really appreciate if either someone could check the drawing for me. Better still if someone could complete the drawing from scratch i could overlay it and see if i have made any mistakes. It not a large drawing so im sure if your good on ISO's it will be quite easy. I would really appreciate it if someone would come to my aid. Thanks Matty Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 30, 2013 Share Posted April 30, 2013 What's wrong with your other thread? Iso Drawing Help "Please Help!" Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 30, 2013 Share Posted April 30, 2013 I guess Matty doesn't want to post a DWG file for review and comment which I suggested in the other thread. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted April 30, 2013 Share Posted April 30, 2013 Threads merged. As mentioned, if you could post the instructions and what you have so far, help is waiting. Quote Link to comment Share on other sites More sharing options...
topgunmatt Posted April 30, 2013 Author Share Posted April 30, 2013 Hi I have attached the files if someone can help ISO-Help.dwg Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 30, 2013 Share Posted April 30, 2013 At first look - it looked pretty good. But on closer inspection - -you are a long way from origin and outside of border. -I would place border in paperspace layout. -I placed a couple of isocircles and yours did not match radius of mine - you have several places that aren't trimmed correctly. Quote Link to comment Share on other sites More sharing options...
topgunmatt Posted April 30, 2013 Author Share Posted April 30, 2013 Thanks, i mainly concerned about the accuracy of the model itself as i have a border/template to add later. Can you highlight the drawing errors and send back to me??? Im really stuck !! Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 30, 2013 Share Posted April 30, 2013 Your radii are wrong and in the plan view that rectangle is not only in the wrong position it also requires at least one extra line. Try again. See where it says, for example, R30? That is the radius for the segment of the circle on the outside of the object. In your drawing the radius is 33. Same goes for all the others. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 30, 2013 Share Posted April 30, 2013 Maybe this view will be better. Jeez, load times today are terrible. What gives? Takes forever. Quote Link to comment Share on other sites More sharing options...
topgunmatt Posted April 30, 2013 Author Share Posted April 30, 2013 Hi Remark, Thanks for your comments, its the isometric that im really concerned about. Can you/anyone see any probs with isometric. If someone could highlight any issues i have and then send me the dwg back it would be good. Thanks Matt Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 30, 2013 Share Posted April 30, 2013 It seems useless to model in isometric in this century when it is so much easier to model in 3D. I'm sure you are just (trying) to follow instructions, but it would be a bit of work (torture) to create the solution file. Maybe someone else will come along and create key. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted April 30, 2013 Share Posted April 30, 2013 Well just for fun I gave it a go as a 2d isometric. Not an impossible problem (I am confident in my solution), but I will make a small wager that your instructor can't do it absolutely correctly. (if you don't give the instructor a warning that I am checking, I might even be willing to make the wager even if the instructor does know I am checking their "solution") I suspect by the time the instructor finishes the "solution" he/she will say, now let's move on to the modern 3D tools. Quote Link to comment Share on other sites More sharing options...
topgunmatt Posted April 30, 2013 Author Share Posted April 30, 2013 Hi JD Thanks for your reply, can you post your Iso dwg file. I'm really looking to see if someone can post there ISO so I can use it as a proof check. Can you help? In willing to PayPal someone for there time if they can produce an exact replication of the scanned picture in the previous page. Thanks Matt Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 1, 2013 Share Posted May 1, 2013 Your plan or top view of the object was wrong therefore I expect your isometric would be wrong too (and it was). Did you redraw it or not? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 1, 2013 Share Posted May 1, 2013 I believe this is the isometric view you are looking for. Quote Link to comment Share on other sites More sharing options...
