  2. I agree 100% I've been on several of the "free STL" sites and that stuff is nice, especially for new people, but I like the satisfaction of knowing I built that and you're definitely right with some of that stuff needing tweaked. I've run into that a few times. I have a Flashforge AD5X and I'm still learning to use the software. If I remember correctly, I just used the STLOUT command to export the file from AutoCAD, then I open Flashforge and click/drag it from my desktop onto my slicer
  3. Like I stated, I still like leaning on AutoCAD for making things for the 3D printer, but also learning Blender and playing with TinkerCAD, etc. The main goal is getting nice 3D Prints, I can tell you from experience, the stuff you get from online, supposedly ready to print, sometimes needs a little tweaking or outright re-modeled. I also have been learning to work in the 3D printer software, in my case, Bambu Studio, it's a lot easier cleaning up, scaling, adding text, etc. right before slicing. Like anyone that uses tools to do a job, learning what tools to use, how to use them, when to use what, etc. is usually the best way to go forward, it's a learning process. By all means start with AutoCAD and improve, we are here to help. Do you know how to export to STL and import that into your slicer?
  4. I messed around a little with tinker cad but figured since I already had some knowledge of AutoCAD that it would probably be more useful to stick with AutoCAD. as I mentioned above, I just started learning AutoCAD in November of last year through Penn Foster (don't hold that against me. I'm basically teaching myself at this point with the help of you fellas).
  5. Today
  6. Well, I just started learning AutoCAD in November of last year through Penn Foster (don't hold that against me. I'm basically teaching myself at this point with the help of you fellas). I didn't realize you could set the text height BEFORE you press pull. I just started the press/pull then typed the number I want. As far as architectural, I'll be honest, that's all we used when I was in college so that's all I really know
  7. Did you try doing these in TinkerCAD? Not sure why your have issues with exploding the text in AutoCAD, I'll look when I get back to work tomorrow. Even as you describe it "When I tried txtexp it shot the text way off to the left and made it huge", you just have to move it and scale it. What you really want to do is learn to do this with the 3D Printer tools. https://www.youtube.com/watch?v=9McpK4nNf2k
  8. Thank you, but I am looking for something more general (I don’t think a LISP will solve the problem). I remember seeing something on YouTube where we can control layer properties without opening the drawings. I uploaded the picture for this specific XREF (x-A2-landscape). I don’t want to change these properties for this xref ....... Your LISP is too specific because, on some floors, more or fewer architectural XREFs are attached.
  9. PaulyPHI
    Set Pline Z value by selecting text
    Thank you very much sir, works perfect. I have compared the modified text file to the original and my brain just melted.... i can see some text that makes sense but the rest is just gobldee goop to me.... I'm just not programmed to understand it... Thank you once again.
  10. Version 1.0.9637
    4 downloads
    EGBoundary is a CAD plugin designed to generate clean outer boundaries from complex 2D drawings. It is intended for situations where standard boundary creation methods may struggle due to: small gaps overlapping geometry dense drawings complex spline/arc combinations EGBoundary is designed to simplify boundary creation workflows and reduce the amount of manual cleanup and time often required in complex drawings. Workflow Overview: Type EGBOUNDARY (Case Insensitive) on command line. Select the drawing geometry Configure tolerance/output settings if required by typing ' S ' on command line Press enter to generate the outer boundary polyline Demonstration Video: CADTEGB.mp4 Key Features: Generates clean closed outer boundaries from selected geometry. Automatic and manual tolerance handling. Supports multiple outer boundary detection from a single selection. Custom output layer and color options. Custom linetype options. Works with large and complex drawings containing many entities. Supports lines, arcs, splines, ellipses, polylines, and blocks. Supports Wipeout generation. Compatibility: AutoCAD BricsCAD GstarCAD ZWCAD Official Website: For more information, updates, documentation, or EGBoundary for other CAD platforms, please visit: Official Website For EGBOUNDARY For any queries related to EGBoundary or CAD customization, feel free to reach out to us at: contact@engenext.com or aniruddha.raste@engenext.com Would really appreciate feedback, suggestions, or difficult test cases from the community.
  11. Don't know what is going on about Textexp but here is a favour for you. I just made A-Z 0-9 exploded. Convert to correct plines then can extrude into a solid say 1 unit high, will need to check the 36 shapes. The sample dwg really needs more thought say text size =1 and height equal say 0.1. It took about 10 minutes to make these. With a bit of practice much faster and use other fonts. You can use presspull to change height. BUT SET TEXT HEIGHT CORRECT BEFORE EXTRUDE. Oh yeah why do you have units set to Architectural when your talking mm ? new block.dwg
  12. Becaus I don't want the drawing to be denser especially when trying calculate the earthwork for a raft with huge number of drops That is why I made this code.
  13. So give this a try. Just load the xrefs in a dwg then run this code will reset all the xref layers. Note will do all current XREFS. Just do it as part of adding the XREFS to current dwg. ; https://www.cadtutor.net/forum/topic/99138-layer-properties/ ; Set all xref colors in a dwg ; By AlanH May 2026 (defun c:setxrefcol ( / lst blk lays xname tc) (setq lst '()) (setq blk (tblnext "BLOCK" T)) (while blk (if (member (logand (cdr (assoc 70 blk)) 4) '(4)) ; bit‑4 = xref (setq lst (cons (cdr (assoc 2 blk)) lst)) ) (setq blk (tblnext "BLOCK")) ) (reverse lst) (setq lays (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) (repeat (setq x (length lst)) (setq xname (nth (setq x (1- x)) lst)) (vlax-for lay lays (setq lname (vlax-get lay 'name)) (if (wcmatch lname (strcat "*" lname "*")) (progn (setq tc (vla-GetInterfaceObject (vlax-get-acad-object) "AutoCAD.AcCmColor.20")) (vla-SetRGB tc 180 180 180) (vla-put-TrueColor lay tc) ) ) ) ) (princ) ) (c:setxrefcol) There is no need to try and do it as a after task.
  14. When I tried txtexp it shot the text way off to the left and made it huge
  15. Just to be clear, I don't mean that the way you did it was wrong. I mean, what can I change earlier in the project to make this part easier? I reread what I wrote and it definitely didn't sound like I meant it to
  16. So this is something I want to set up so that I can do multiples and just change the name and number. What's the easiest way to go about this? Doing what you did, seems like there's gotta be an easier, more efficient way from the begginning...lol
  17. Ok I used Txtexp on "MACEY", then went to a 3d view so could see what was going on VPOINT -1,-1,-1. You have to check that all the objects that appear are plines I had to join the little "A" triangle. Ok extruded the base 1.5 Extruded the circles 2.5, then unionid both, to base, subtracted the inner circle from the new solid. Extruded the ""M" 4.5 then did a union again. Extruded the two parts of the "A" unioned together with base then subtracted the inner triangle, You can see the progress. What you want is not a single step but rather multiple steps, lastly can export the STL file. Once you get the hang of extruding, subtrcat and union you can do multiple objects at one time. This is a bit rough as a solid and can be done better, by moving the text to a Z matching base height before you start.
  18. Yesterday
  19. Why not just use the inbuilt "FEATUREELEVSFROMSURF "
  20. Sorry it took so long to get back. I never got notifications that there were any replies. OK, so maybe I'm missing something here and ChatGPT and Gemini are of zero help so far. I have this drawing. I'm trying to make a 3d printed ATV number plate. Extrude absolutely won't work for me, not sure why. I was able to use the "presspull" command to punch out the holes (which I don't believe is the correct way) and I can raise the plate up the 3mm I want and the support around the holes the additional 1mm I want but it absolutely won't do anything with the text. I tried MTEXT and single line text. Neither works My printer is a FlashForge AD5X Mark Macey Rear Plate.dwg
  21. Hi everyone, I’m working on a complex borehole location drawing in AutoCAD with many boreholes and corresponding data tables. When a new borehole is added, I would like to have an AutoLISP routine that can automatically place a new table and leader for that borehole without overlapping the existing tables. The layout concept is roughly like the attached image: Each borehole is a point/block near the center of the drawing. Each borehole has a data table placed outside the central cluster. A leader (polyline or multileader) connects the borehole to its table, using straight segments and preferably angles that are multiples of 60 degrees (or similar fixed angles). When space on one side is not available, the routine should try other directions until it finds a free spot between the existing tables. What I would like the routine to do is: Take the new borehole (block or point) as input. Use a standard table block (or AutoCAD table) with a known size and insertion point. Search along several radial directions (0°, 60°, 120°, 180°, 240°, 300° or similar) at a given distance to find a position where the table’s bounding box does not overlap existing tables or a central “no‑go” area. Insert the new table at the first (or best) free position and draw the leader from the borehole to the table with clean, orthogonal/60° segments. I have some AutoLISP experience and I’m thinking about using: Block/table bounding boxes (vla-getBoundingBox) for collision checks. Simple rectangle overlap tests to avoid collisions. Polar coordinates for candidate positions at fixed angles and distances. Before I start building this “placement engine” from scratch, I’d really like your feedback: Has anyone already written something similar (automatic table/label placement around a central cluster, avoiding overlaps)? From your experience, is this approach (block + attributes + leader + bounding‑box collision tests) reasonable, or is there a better pattern? Any tips on robust overlap detection or examples of similar LISP routines you recommend looking at? Would you implement this with standard tables, block attributes, or something else for the borehole information ? Any ideas, sample code, or links to existing routines would be greatly appreciated. Thanks in advance for your time and suggestions! ** Find attached plz 11.pdf
  22. Hi Again for example, here I have 4 xref attached, I need to change the layers properties (make color 180,180,180 and line weight =default) for these xrefs without opening all drawings. Thank you for your time
  23. darshjalal
    PETA-INSERT ELEVATIONS FROM TEXTS INSIDE THE CLOSED OR OPEN POLYINE.LSP Try this one too
  24. Last week
  25. @ababs "actually we attach the architectural drawings as xref " so why not do the changes then as part of an custom attach xref lisp. Again need an idea of what the layer names are and the relevant changes. How do you propose to identify the layers ? By wildcards "wall*" etc Were I worked we redid the color of layers by wildcards about 7 of them. So maybe 50 layers.
  26. hello actually we attach the architectural drawings as xref after finishing our mechanical plans we have to publish so we got to change xref's layers properties excpt for title block(which is also xref)
  27. Updating version of the previous code> Regards. 3DSLOPE-automates the creation of 3D Polylines, level labels, and slope percentages -R2.LSP
  28. You can use possibly OBDX which can edit a dwg without opening it. Using a script is much simpler as it will open a dwg make the edits then close it. Should be reasonably fast. The obvious first step is what are you trying to change ? You need say a text file with the new settings, layer name, color, linetype on/off and so on. So if I understand correct another way, the sequence may be open a dwg add the xref do the layer changes save and close do next dwg. So what I am asking here does original dwg always have the xref pre loaded. Need sample dwg, txt and a xref. Can be blank just need layers,
