  2. Today
  3. CivilTechSource
    Name my Roads
    Hi all, Thanks again for all the help and feedback. @GLAVCVS - Would it not cause more issues condensing the prompt of selecting the polyline & start point will cause in some cases error if we are at a junction and we have two polylines opposite each other? Thanks for the geometric mid-point tip! @BIGAL - Re-layer check, I tested it on a blank drawing without that layer and it worked, no crash. I do like the idea of creating small lisp functions for repetitive stuff. I did not understand the " pline vertice points, thanks to lee--mac." Does making a list of entities is less process intensive? How did I not think about adding check if roads are numbered! Thanks that is handy and very nice to have. So I have a generic question, when creating a lisp which approach is best: - Create it as simple as possible OR - Develop it so its almost its own mini app? (e.g. we could feature to auto-update road numbers feature by specifying the road centreline layer, so if the lisp detects a new polyline that touches the rest of the road network it would add it). Not sure if it will be any good, but I did start a github repo for lisps I create as I go. https://github.com/CivilTechSource/AutoCAD-Lisps-4-All
  4. Hi zaphod, Thank you so much for testing it out and sharing this feedback! 1. Auto-filling Asset Name from File Name: Absolutely agreed! You’re 100% right—when you browse and select a file like AreaCalc.lsp, the system should intelligently parse (vl-filename-base) and automatically pre-fill "AreaCalc" into the Asset Name if the field is empty. This eliminates repetitive typing when adding a batch of local tools. We are incorporating this directly into the next build! 2. Defaulting Version to 0: Why we intentionally keep it blank. You bring up an interesting point, but keeping the Version field blank is actually a deliberate architectural design choice on our end. In VedaCAD's ecosystem, published version numbers are immutable once uploaded to ensure clean version tracking and hot-updates. If we pre-fill 0, a user adding a local script and casually clicking "Publish" would permanently stamp their cloud asset with version 0 without making a conscious choice. Leaving the field blank forces a brief pause, ensuring authors explicitly set a structured initial version (such as 1.0 or 1.0.0), which keeps the public ecosystem metadata clean and reliable for everyone. Really appreciate you taking the time to share these ideas—feedback like this helps us fine-tune both the user experience and the underlying discipline! Vico
  5. Nice Lisp VicoWang! This looks like a great solution to the dreaded startup suite, some suggestions; Is it possible to have the "Asset Name" be the file name by default? Could the "Version" field default to 0?
  6. KraZeyMike
    Changing the precision of fields
    Please see attached I have a Block and mText Field linked to the same Boundary. currently the mText works great but would like to have the option of amending the precision within the block also. Field Precision.dwg
  7. To change a field in a block you would need to iterate through all the objects defining that block so finding a text or attribute object within, then update, a text is a singular object. Not sure with a block can do just one or need to edit the block definition. This will fail for a block (setq value_string (vla-FieldCode Obj) nbs 0) you need to check each individual entity as Obj. It may be best to post a sample dwg, with text and blocks.
  8. BIGAL
    Name my Roads
    Updated code above it now looks for existing labels and gets the last number and adds 1. Still a couple of things to improve but will leave that to @CivilTechSource to look at. I added a get angle at point defun.
  9. KraZeyMike
    This is great, I really like the code from Tsuky. Thankyou for this and works great for stand alone text/mtext. Out of curiosity I can select blocks by adding ....,INSERT") to the ssget function. Just wondering if it can be amended to change the precision of fields within selected blocks as well as stand alone text? (vl-load-com) (defun c:change_prec ( / ss AcDoc Space prec_source ktarget n ename Obj value_string nbs tmp_nbs) (princ "\nSelect MText.") (while (null (setq ss (ssget (list '(0 . "*TEXT,INSERT") (cons 67 (if (eq (getvar "CVPORT") 1) 1 0)) (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model")) ) ) ) ) (princ "\nAren't MText or Text!") ) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (vla-startundomark AcDoc) (initget 1 "0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Current") (setq ktarget (getkword "\nPrecision of target number [0/1/2/3/4/5/6/7/8/9/10/11/12/13/14/15/16/Current]?: ")) (repeat (setq n (sslength ss)) (setq ename (ssname ss (setq n (1- n))) Obj (vlax-ename->vla-object ename) ) (setq value_string (vla-FieldCode Obj) nbs 0) (cond ((vl-string-search "%<\\" value_string nbs) (while nbs (if (setq nbs (vl-string-search "%pr" value_string (setq tmp_nbs nbs))) (setq prec_source (itoa (atoi (substr value_string (+ nbs 4) 2))) value_string (vl-string-subst (if (eq ktarget "Current") (strcat "%pr" (itoa (getvar "LUPREC"))) (strcat "%pr" ktarget) ) (strcat "%pr" prec_source) value_string tmp_nbs ) nbs (1+ nbs) ) ) ) (vlax-put Obj 'TextString value_string) ) ) ) (vla-endundomark AcDoc) (prin1) )
  10. @CyberAngel this may be useful, it is what we used every day, we had a JPG and a JGW file. rescale image.lsp
  11. Yesterday
  12. Hi everyone! As an architect and 3D artist, I developed AlphaButton Drawing Generator — a native 3ds Max plugin designed to automate the creation of technical CAD drawings, vector PDFs, and editable 2D DXF files directly from the 3ds Max viewport in just 2 clicks: Select geometry ➔ Click Generate. Generate professional technical drawing sets in vector PDF and 2D DXF formats (compatible with AutoCAD, SolidWorks, Rhino, and major CAD/CAM software) directly inside 3ds Max 2025–2027 — no manual rebuilding required. How It Works — 2 Simple Steps: Select Geometry — pick the objects in your 3ds Max viewport. Generate PDF or DXF — click GENERATE PDF or GENERATE DXF. The plugin automatically builds the layouts and opens the final file for instant review, printing, or CAD/CAM fabrication. Designed as a perfect fit for: • Client Presentations & Design Reviews — clean concept drawings and realistic shaded layouts directly from your viewport. • Furniture Manufacturing & Joinery — isolate individual parts and generate clean, exact dimensions for local, CNC, or industrial production. • Workshop & Assembly Documentation — component blueprints, section cuts, and structured bills of materials (BOM) for the shop floor. Compliance with Engineering & CAD Standards: • Vector PDF & 2D DXF Export — exports production-ready vector PDFs for print and presentation, or fully editable 2D DXF files (AutoCAD DXF R2007 / AC1021 format or newer) for AutoCAD, SolidWorks, Rhino, and CAM cutting software. • Dual Unit Systems — full support for both Metric (mm) and Imperial (in) units with 1:1 real-world scale accuracy. • Projection & Section Views (ISO 128 / ASME Y14) — 3 visual presentation styles: Shaded with Visible Edges, Visible Edges Only (classic CAD blueprints), and Visible + Hidden Edges (dashed lines for internal cavities and joinery). • Drawing Borders & Title Blocks (ISO 5457 / ISO 7200) — automated layout borders, project metadata, author signatures, and revision dates. • Detail Sheets (ISO 129-1 / ISO 5455) — unique components auto-extracted to dedicated individual drawings with standard scale ratios (1:1, 1:2, 2:1, etc.). • Automated Bill of Materials (ISO 7573) — structured specification tables listing all parts, quantities, and dimensions, automatically linked to drawing balloon callouts. Video Demos of the Workflow: • 2D DXF Export & CAD Import: Try it free for 14 days (One click, no email, no registration, no credit card required): Download Free Trial on Patreon: System & Geometric Requirements: • Autodesk 3ds Max: 2025, 2026, or 2027. • Geometric Compatibility: Works best with native 3ds Max geometry (primitives, parametric extrusions, Editable Poly/Mesh) with clean smoothing groups and active modifiers. Avoid organic/sculpted geometry or collapsed booleans for detail dimensioning. I would highly appreciate your honest feedback, testing results, or constructive critique from the CADTutor community! Thank you for your time and support! Best regards, Liubomyr Hrytsai Creator of AlphaButton Drawing Generator Patreon: https://www.patreon.com/AlphaButton AlphaButton_Sample_Drawing_Set_(ASME_Imperial).pdf AlphaButton_Sample_Drawing_Set_(ISO Metric).pdf
  13. We use Civil 3D, so we have more tools. Typically we get a batch of points in state plane coordinates. That means you can draw a line anywhere along the Y axis of those coordinates and get a fairly accurate North. It's not totally accurate because, obviously, that same vertical line is parallel at the ends of your state, which can be hundreds of miles apart. That's what a datum is for, I guess, to reconcile the grid with the surface of the Earth. This seems like a simple problem, but it's a nightmare if you don't have enough data. What I'll typically do is get a screen grab from an aerial map, making sure it's oriented to North, at a known scale, with a graphic scale included. Add that image to the drawing as an Xref at rotation 0. Scale it so that the graphic scale is correct. Then the fun part: find locations that match your drawing and line them up. Then the nightmare part: keep in mind that aerial images aren't always taken from directly above that area, so there's going to be some skew--and you have no way of knowing what that skew factor is. Sometimes you have to decide which points are more important to get right and let the rest be off. There's a command named ALIGN, which is very handy here: pick two or three points from the image and the corresponding points from the drawing; decide whether to scale the image; and watch the magic. With a drone you could get an image from a known spot, but not everyone has access to a drone. Other strategies: look for benchmarks in your drawing. In the US there's a system of markers placed by the Geodetic Survey. Surveyors often begin their locating from a benchmark, geodetic or otherwise. What you're trying to do is find three points that will define a plane. The other strategy only works if you know some property corners or can locate them: get a plat (not a deed, those cost money) for a piece of property. It will include bearings and distances for each border line. That gives you distance and direction between your property corners, so you can define your plane. Of course all these strategies depend on the drawing being in World UCS. You sometimes find a Plan North, and you can create a UCS to match that. Orienting the drawing to some other UCS will lead to problems down the line, I've been there.
  14. BIGAL
    Name my Roads
    Had a play took a different tack, still needs some more improvements. The angle returned at a pline point determines wether the label goes below or on top that needs to be looked also. But it does use a Mid point method. needs localising of variables etc. Call it version one. ; https://www.cadtutor.net/forum/topic/99216-name-my-roads/ ; label roads by CivilTechSource Jukly 2026 ; Modified by AlanH July 2026 ;;; ========================================================================= ;;; USER CONFIGURATION - EDIT THESE VARIABLES EASILY ;;; ========================================================================= ;;; Check does layer exist (defun chklay (layn color ltype / ) (command "-layer" "make" layn "C" color "" "LT" ltype "" "") ) (defun alg-ang (obj pnt) (angle '(0. 0. 0.) (vlax-curve-getfirstderiv obj (vlax-curve-getparamatpoint obj pt ) ) ) ) ;; Parse Numbers - Lee Mac ;; Parses a list of numerical values from a supplied string. (defun LM:parsenumbers ( str ) ( (lambda ( l ) (read (strcat "(" (vl-list->string (mapcar '(lambda ( a b c ) (if (or (< 47 b 58) (and (= 45 b) (< 47 c 58) (not (< 47 a 58))) (and (= 46 b) (< 47 a 58) (< 47 c 58)) ) b 32 ) ) (cons nil l) l (append (cdr l) '(())) ) ) ")" ) ) ) (vl-string->list str) ) ) (defun ahfindlast (rdents / x road-entity txt newnum) (setq x 0 global:road-counter 0) (while (< x (sslength rdents)) (setq road-entity (ssname rdents x)) (setq txt (cdr (assoc 1 (entget (ssname rdents x))))) (princ (strcat "\npline already labelled " txt)) (setq newnum (car (LM:parsenumbers txt ))) (if (= newnum nil)(setq newnum 1)) (if (> newnum global:road-counter)(setq global:road-counter newnum)) (setq x (1+ X)) ) (setq global:road-counter (1+ global:road-counter)) (princ) ) ;;; MTEXT CREATION FUNCTION (WITH ROTATION & READABILITY LOGIC) (defun action-label-road (road-entity number road-text-layer road-text-color road-text-height pt / ang readable-ang ) (setq ang (alg-ang road-entity pt)) (if (and (> ang (/ pi 2.0)) (<= ang (* pi 1.5))) (setq readable-ang (+ ang pi)) ; Flip 180 degrees if necessary (setq readable-ang ang) ; Keep original angle otherwise ) (setq pt (polar pt (- (/ pi 2.0) ang) road-text-height)) (entmake (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 8 road-text-layer) ; Applies your layer (cons 62 road-text-color) ; Applies your color (cons 100 "AcDbMText") (cons 10 pt) ; Places text at the middle of the road (cons 40 road-text-height) ; Applies your text size (cons 50 readable-ang) ; <--- APPLIES CALCULATED READABLE ROTATION (cons 71 5) ; Forces "Middle Center" alignment (cons 1 (strcat global:road-prefix " " (itoa number))) ; Text content ) ) (setq global:road-counter (1+ global:road-counter)) (princ) ) ;;; ========================================================================= ;;;;;;;;;; Starts here ;;;;;;;;;;;;;;;; (vl-load-com) ; Loads advanced geometry functions for handling polylines (defun c:NumberRoads ( / dist obj road-default-prefix road-ss road-sstxt user-prefix x) ; (setq road-text-height 2.5) ; How tall the road number text should be ; (setq road-text-layer "Road-Labels") ; The layer where the text numbers will go ; (setq road-text-color 2) ; Color index for the text numbers (2 = Yellow) (setq road-default-prefix "Road") ; The default name if you just press Enter (chklay "Road-Labels" 1 "Continuous") ; Does layer exist check (setq road-sstxt (ssget "X" (list (cons 0 "*text")(cons 8 "Road-Labels")(cons 410 "Model")))) (if (= road-sstxt nil) (alert "No existing labels ") (ahfindlast road-sstxt) ) (princ "\nSelect all polylines and lines that make up the new road network: ") (setq road-ss (ssget '((0 . "LINE,*POLYLINE")))) (if road-ss (progn (if (= global:road-counter nil)(setq global:road-counter 1)) (setq grc (getint (strcat "\nEnter new Road profile number eg " (rtos global:road-counter 2 0) " "))) (if (= grc nil) (princ) (setq global:road-counter grc) ) (setq user-prefix (getstring t (strcat "\nEnter road prefix <" road-default-prefix ">: "))) (if (= user-prefix "") (setq global:road-prefix road-default-prefix) (setq global:road-prefix user-prefix) ) (setq x 0) (while (< x (sslength road-ss)) (setq road-entity (ssname road-ss x)) (setq obj (vlax-ename->vla-object road-entity)) (setq dist (/ (vlax-get obj 'length) 2.0)) (setq mid-param (vlax-curve-getpointatdist obj dist)) ; road-entity number road-text-layer road-text-color road-text-height (action-label-road obj global:road-counter "Road-Labels" 2 2.5 mid-param) (setq x (1+ X)) ) ) ; progn ss (princ) ) ; if ss (princ) ) (c:NumberRoads) I am leaning towards making the input here much bigger rather than lots of setq's just set default values in the defun call. Or use a dcl to set values.
  15. Hi BIGAL, First off, thank you for sharing your perspective on how the community and your clients are handling the "cloud" today. It’s really insightful to hear where the landscape actually stands from someone with your experience. You’re spot-on that most people currently just map AutoCAD Support Paths to a static cloud drive folder. And that "In office" / "Out of office" dual-icon setup you mentioned? That is a brilliant piece of classic IT problem-solving! It perfectly captures the exact nightmare CAD Managers have dealt with for years when engineers take laptops to construction sites. Analyzing those classic IT workarounds highlights that the core deployment challenges in CAD haven't changed, but modern architectures give us new ways to tackle them. At their core, almost all traditional methods—whether passing local ZIPs or mapping static cloud drives—rely on static distribution. Once a file leaves the source, its connection is severed, inevitably leading to version fragmentation across the firm. This is exactly why we designed VedaCAD to provide dynamic lifecycle management through a "Cloud-Managed Local Sandbox", rather than just live cloud mapping. From an engineering standpoint, here is how we structured the technical measures to handle those specific scenarios: Solving the offline field scenario Mapping directly to a cloud drive introduces fragility—if the internet drops, CAD freezes. To prevent this, everything in our architecture physically runs from a local sandbox cache on the C drive. The client simply pings the server with a lightweight heartbeat. If an engineer opens their laptop on a site with zero Wi-Fi, the LISP kernel silently transitions into Offline Mode. They keep drawing seamlessly using their local cache until the configured offline grace period expires. No need for separate desktop icons. Managing binary updates and file locks When a developer patches a .vlx or .dll, expecting users to manually download and replace ZIPs leads to version fragmentation. We shifted this to a heartbeat-driven sync. When the server detects a version drift, the update is pulled into the sandbox. Depending on the workspace policy (Manual, Auto, or Enforced), the user either clicks to approve it, or the engine hot-swaps it silently in the background. To bypass Windows file locks on running binaries, the engine utilizes a backend .bak renaming trick to perform the in-place replacement without crashing CAD. Resolving subcontractor environment consistency How do we ensure that all subcontractors perfectly align with the drafting standards set by the general contractor, even down to the absolute uniformity of a single linetype color? We tackled this by building isolated containment fields we call "Project Arks". Instead of emailing ZIP files of CAD standards, a General Contractor can package their absolute drafting environment and issue a time-limited "Visa". When a subcontractor mounts it, their CAD temporarily mirrors the GC's standard. Crucially, if the GC updates a .ctb or other environment configuration files mid-project, the subcontractors pull the latest standard on their next heartbeat or upon manual sync, allowing the GC to monitor exactly which external terminals are lagging on outdated standards. Asset revocation and self-healing If a subcontractor's Visa expires, or an internal employee's device is unbound, the system relies on a zero-trust model. Upon the next ping, the engine executes a remote kill-switch, physically shredding the proprietary CAD assets from the local cache. Conversely, if a user accidentally deletes a cached plugin, the LISP reactor detects the loss via a native (findfile) check and instantly auto-fetches the replica from the cloud, ensuring the execution chain never breaks. It’s always a pleasure geeking out over deployment architectures with veterans. Thanks again for the great discussion! Cheers, Vico
  16. BIGAL
    Name my Roads
    Did not look to hard but an obvious one for me was. (setq road-text-layer "Road-Labels") ; The layer where the text numbers will go If layer "Road=labels" does not exist then program will crash, IF does not exist so just "Make" the layer. In lots of code I am writing I will take advantage of a global defun that is in another preloaded lisp, it has a checklayer function. This something like all you would need. (chklayer "Road-Label" 1 "Continous") (setq road-text-layer "Road-Labels") Agree with other post label at mid point, Using vertices can get be returned form a pline that is drawn in wrong direction than you think. Yours (setq current-dist-start (vlax-curve-getDistAtPoint road-entity start-pt)) I have a swap or flip a pline so start direction is from end selected. But using mid solves this. May not need this function if using mid. There is VL get coordinates that returns all the vertice XYZ. (defun helper-find-and-sort-intersections (setq lst (vlax-safearray->list (vlax-variant-value (vla-get-coordinates obj)))) Also this for pline vertice points, thanks to lee--mac. (setq plent (entsel "\nPick rectang")) (if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent)))))) (princ co-ord) Just another idea when doing add more items to an existing drawing, do a "does the labels exist already" ? If so then get them all and find last label then add one to it. You have a layer name so can ssget MTEXT for that layer. Just me I don't tend to do this, make a list of entities, then process that list. It's a personal preference (while (setq entity (ssname road-ss i)) (setq global:all-roads (cons entity global:all-roads)) (setq i (1+ i)) ) I just act on the current entity returned by the while or a Repeat and do the labelling of that entity. This is sort of double handling the SSGET if you use Pick PIck Pick method the selection set should be in the pick order (setq first-road (car (entsel "\nSelect the FIRST road (from your selection): "))) Otherwise use a Pick and label method it will be fast. The label will appear as fast as you pick. Maybe even a dual method pick and window. Having a bit of a look I think code can be shortened a lot.
  17. @VicoWang I don't do anything with the clous but I know some of my clients are going that way for various reasons, in the very simple way the Install.lsp works there is no reason why the programs etc can not be loaded to the cloud. You only need correct support paths hopefully set, I don't use the cloud. One other thing is we had laptops where I worked, so when outside in the field the user would select the correct icon on the desktop, we had two icons "In office" and "Out of office" then the correct profile was loaded. The "out of office" would look on the laptop for programs etc, Yes had a slightly different set of menu's. The profile choice is in the ICON properties.
  18. Last week
  19. GLAVCVS
    Name my Roads
    Hello. May I make a suggestion? Perhaps you could simplify the user prompts from this: (setq first-road (car (entsel "\nSelect the FIRST road (from your selection): "))) (setq start-point (getpoint "\nClick near the START point of the first road: ")) to a single prompt: (setq first-road (car (setq es (entsel "\nSelect the FIRST road near the START point (from your selection): "))) start-point (cadr es) ) Also, your code calculates the midpoint based on the number of vertices rather than on the actual distance along the road. You might prefer to place the label at the geometric midpoint by replacing this: (setq mid-param (/ (vlax-curve-getEndParam road-entity) 2.0)) with this: (setq total-dist (vlax-curve-getDistAtParam road-entity (vlax-curve-getEndParam road-entity)) mid-param (vlax-curve-getParamAtDist road-entity (/ total-dist 2.0)) )
  20. Type VC to start. Read it on the command line when loading .VLX.
  21. i got .vlx file and i dont know the command pls
  22. VicoWang
    AI taking over
    Watching this whole "AI taking over" debate unfold, I feel like I'm seeing people in our industry fall into three different camps: First, there’s the Spectator. They use AI to generate flashy concept art or write basic emails. It’s pure consumption—cool to look at, but they don't really know how the engine works. Then you have the Skeptical Co-Pilot. This is where I sit for my daily development. You let AI do the heavy lifting for specific, tedious tasks, but you absolutely do not trust it blindly. You sandbox its output and rigorously test it before ever putting it into your actual workflow. Finally, there’s the Blind Believer. This is the whole "AI Agent" crowd trying to run a one-man firm. They type a prompt and expect a flawless final product the next morning. The reality? You have no idea what kind of spaghetti code or geometric garbage is hidden inside that black box, and auditing it takes longer than just doing the work yourself. Speaking of that "skeptical co-pilot" approach, I actually went down a massive rabbit hole with it recently. I was trying to solve a very pragmatic problem: How do we get an LLM to generate hyper-precise CAD geometry without eating up a million tokens and spitting out hallucinated garbage? Natural language just doesn't cut it for drafting. So, I worked with an AI to invent a prototype "Universal Morphological Matrix" (I just call it V-Code). The idea was to strip away all the human linguistic fluff and reduce CAD commands down to an absolute, 256-token hex-based root system. It basically compresses professional CAD knowledge into a tiny "Cosmic Language", which a local interpreter can then unpack back into precise AutoCAD/LISP commands. I pushed the experiment so far that I jokingly asked the AI to use this highly compressed logic to solve the P vs NP math problem. It confidently spit out a bunch of hex codes and claimed it had solved it. Did I believe it? Absolutely not, because I couldn't read its alien derivation track at all, haha! At the end of the day, AI is an incredibly powerful engine. But if you take your hands off the steering wheel and just blindly trust the machine, you're going to crash. It remains a tool exclusively for people who already know exactly what they are doing.
  23. CivilTechSource
    Name my Roads
    Hi, With help of AI I manage to get this lisp working. Name my Roads. Allows the user to select number of polylines and then select starting polyline (Road) and names all the rest. I would welcome any further improvements on it. ;;; ========================================================================= ;;; USER CONFIGURATION - EDIT THESE VARIABLES EASILY ;;; ========================================================================= (setq road-text-height 2.5) ; How tall the road number text should be (setq road-text-layer "Road-Labels") ; The layer where the text numbers will go (setq road-text-color 2) ; Color index for the text numbers (2 = Yellow) (setq road-default-prefix "Road") ; The default name if you just press Enter (setq error-circle-radius 5.0) ; How big the warning circles should be (setq error-circle-layer "Unnamed-Roads") ; Layer for roads that were skipped (setq error-circle-color 1) ; Color for warning circles (1 = Red) ;;; ========================================================================= (vl-load-com) ; Loads advanced geometry functions for handling polylines (defun c:NumberRoads ( / road-ss user-prefix first-road start-point i entity) ;; Reset our trackers (setq global:road-counter 1) (setq global:all-roads '()) (setq global:visited-list '()) (princ "\nSelect all polylines and lines that make up the road network: ") (setq road-ss (ssget '((0 . "LINE,*POLYLINE")))) (if road-ss (progn ;; Convert the selection set into a clean list of entities for the algorithm (setq i 0) (while (setq entity (ssname road-ss i)) (setq global:all-roads (cons entity global:all-roads)) (setq i (1+ i)) ) (setq user-prefix (getstring t (strcat "\nEnter road prefix <" road-default-prefix ">: "))) (if (= user-prefix "") (setq global:road-prefix road-default-prefix) (setq global:road-prefix user-prefix) ) (setq first-road (car (entsel "\nSelect the FIRST road (from your selection): "))) (setq start-point (getpoint "\nClick near the START point of the first road: ")) (if (and first-road start-point) (progn ;; Start the main driving loop (explore-road-logic first-road start-point) ;; SCAN FOR UNNAMED ROADS: Look for any lines left behind (foreach entity global:all-roads (if (not (member entity global:visited-list)) (action-mark-unnamed entity) ) ) (princ "\nRoad numbering complete! Skipped roads have been marked with red circles.") ) (princ "\nMissing first road or start point selection.") ) ) (princ "\nNo roads were selected.") ) (princ) ) ;;; CORE LOGIC FUNCTION (defun explore-road-logic (current-road current-start-pt / road-num intersections intersection-info next-road next-pt) (setq road-num global:road-counter) (setq global:visited-list (cons current-road global:visited-list)) (action-label-road current-road road-num) (setq intersections (helper-find-and-sort-intersections current-road current-start-pt)) (foreach intersection-info intersections (setq next-pt (car intersection-info)) (setq next-road (cdr intersection-info)) (if (not (member next-road global:visited-list)) (progn (setq global:road-counter (+ global:road-counter 1)) (explore-road-logic next-road next-pt) ) ) ) ) ;;; MTEXT CREATION FUNCTION (WITH ROTATION & READABILITY LOGIC) (defun action-label-road (road-entity number / mid-param mid-pt deriv ang readable-ang) (setq mid-param (/ (vlax-curve-getEndParam road-entity) 2.0)) (setq mid-pt (vlax-curve-getPointAtParam road-entity mid-param)) (setq deriv (vlax-curve-getFirstDeriv road-entity mid-param)) (setq ang (angle '(0 0 0) deriv)) ; Convert vector to angle in radians (if (and (> ang (/ pi 2.0)) (<= ang (* pi 1.5))) (setq readable-ang (+ ang pi)) ; Flip 180 degrees if necessary (setq readable-ang ang) ; Keep original angle otherwise ) (entmake (list '(0 . "MTEXT") '(100 . "AcDbEntity") (cons 8 road-text-layer) ; Applies your layer (cons 62 road-text-color) ; Applies your color '(100 . "AcDbMText") (cons 10 mid-pt) ; Places text at the middle of the road (cons 40 road-text-height) ; Applies your text size (cons 50 readable-ang) ; <--- APPLIES CALCULATED READABLE ROTATION '(71 . 5) ; Forces "Middle Center" alignment (cons 1 (strcat global:road-prefix " " (itoa number))) ; Text content )) ) (defun action-mark-unnamed (road-entity / mid-param mid-pt) (setq mid-param (/ (vlax-curve-getEndParam road-entity) 2.0)) (setq mid-pt (vlax-curve-getPointAtParam road-entity mid-param)) (entmake (list '(0 . "CIRCLE") '(100 . "AcDbEntity") (cons 8 error-circle-layer) (cons 62 error-circle-color) '(100 . "AcDbCircle") (cons 10 mid-pt) (cons 40 error-circle-radius) )) ) (defun helper-find-and-sort-intersections (road-entity start-pt / road-vla intersections-list current-dist-start other-vla int-points pt dist rel-dist abs-rel-dist) (setq road-vla (vlax-ename->vla-object road-entity)) (setq current-dist-start (vlax-curve-getDistAtPoint road-entity start-pt)) (if (not current-dist-start) (setq current-dist-start 0.0)) (setq intersections-list '()) (foreach other-entity global:all-roads (if (and (not (eq road-entity other-entity)) (not (member other-entity global:visited-list))) (progn (setq other-vla (vlax-ename->vla-object other-entity)) (setq int-points (vlax-invoke road-vla 'IntersectWith other-vla 0)) (if int-points (while int-points (setq pt (list (car int-points) (cadr int-points) (caddr int-points))) (setq int-points (cdddr int-points)) (if (vlax-curve-getDistAtPoint road-entity pt) (progn (setq dist (vlax-curve-getDistAtPoint road-entity pt)) (setq abs-rel-dist (abs (- dist current-dist-start))) (if (> abs-rel-dist 0.01) (setq intersections-list (cons (list abs-rel-dist pt other-entity) intersections-list)) ) ) ) ) ) ) ) ) (setq intersections-list (vl-sort intersections-list '(lambda (a b) (< (car a) (car b))))) (mapcar '(lambda (x) (cons (cadr x) (caddr x))) intersections-list) )
  24. What if creating a CAD block was as simple as describing it, letting you spend less of your time drafting and more time designing? My team at Autodesk is exploring how AI can simplify some of your core CAD workflows. Starting today, you can get an inside look into the future of the AutoCAD portfolio through our new Tech Previews on AutoCAD on the web. We have lots more ideas in the works, and we can’t wait for you to try them! Our first Tech Preview is Block Generate with AI. You can use natural language to generate a 2D block. In the description, you can specify the shape. Some examples: 3-seater sofa with 3 cushions Double vanity with round bowls and rounded corners Round table with four chairs Double door with equal leaves and 90-degree swing arcs Designed to help you get to design faster Blocks are a fundamental part of many AutoCAD workflows, but creating a new one can interrupt your momentum. Block Generate with AI is designed to help you quickly generate a starting point so you can spend less time creating common objects and more time designing. Because the generated block is editable, you remain in control. You can modify the geometry to meet your project’s needs before incorporating it into your drawings. As a Tech Preview, generated geometry may need some editing, particularly dimensions, as we continue developing the experience. Your feedback will help us improve future iterations. Try it and tell us what you think Block Generate with AI is available as a Tech Preview in AutoCAD on the web. If you’d like to learn how to enable the Tech Preview, write effective prompts, and start generating blocks, check out our Block Generate with AI Help article. Which block will you generate first? We’d love to hear your ideas in the Autodesk Community. The post Introducing Block Generate with AI: An AI Tech Preview for AutoCAD on the web appeared first on AutoCAD Blog. View the full article
  25. download: https://www.vedacad.com/ type code: A7CEHQ Drawing test MPL: https://drive.google.com/file/d/1WgMLRDxaiLchbshI3o_f3WHrV7rHX03e/view?usp=sharing AutoCAD: https://shrinkme.click/Multi_Plot_MPL BricsCAD: https://shrinkme.click/Multi_Plot_MPL_BricsCAD ZwCAD: https://shrinkme.click/Multi_Plot_MPL_ZwCAD
  26. Generally users of AutoCAD Map and it's verticals use DVIEW (Command) Twist option to change the orientation of viewports if the software didn't automatically twist it when the sheet was created to either better show the work area or with Plan & Profile sheets the Plan view's baseline is orientated horizontal to align with the Profile view. North is rarely exactly straight up on a viewport! There should always be a North arrow and a graphic scale on every map. If not plotted at 1:1 the graphic scale will not measure correctly. Not sure what you mean by "north arrow was not very clear"? Never used an "online compass" but always viewed project areas with Google Maps or GIS software to check orientation and make sure there wasn't anything missing on my drawing.
  27. Welcome to CadTutor CamDuy and thank you for sharing your program, looks like you put a lot of effort in this. The world (and this site) needs more people like you
  28. here's a dump from the BRep sample I posted here brep.txt
  29. 3D Solid.dwg I’ve attached a sample DWG. When I run: (setq SOLID (ssget '((0 . "3DSOLID")))) (setq data (entget (ssname SOLID 0))) I get this result: When I run: (setq data (vlax-ename->vla-object (ssname SOLID 0))) I get this result instead:
