OrangeFu Posted February 23, 2013 Share Posted February 23, 2013 Hello folks, Background: During the process of drafting many lines overlap (e.g. construction lines, objects merging, etc) Because the overlapping lines have precisely the same properties, I don't feel the need to remove them. The issue begins when I go to plot. The overlapping lines do appear darker than lines without overlapping. This occurs a great deal in my work! My question is this: Is there a function that will (forgive my Photoshop lingo) merge/flatten these lines so that no more overlapping lines exist? Going in one at a time is tedious business! Thanks, George Quote Link to comment Share on other sites More sharing options...
MSasu Posted February 23, 2013 Share Posted February 23, 2013 Please check the OVERKILL command (part of Express extension pack). Although, if the overlapped parts appear darker, then it is possible that they don't really overlap, but were drawn parallel at very small distance, so not sure if the above solution will help. Quote Link to comment Share on other sites More sharing options...
OrangeFu Posted February 25, 2013 Author Share Posted February 25, 2013 This worked perfectly. Thank you so much!!! Quote Link to comment Share on other sites More sharing options...
MSasu Posted February 25, 2013 Share Posted February 25, 2013 You're welcome. OrangeFu! Quote Link to comment Share on other sites More sharing options...
