f700es Posted September 14, 2019 Posted September 14, 2019 2 hours ago, BIGAL said: Zwcad its another clone I agree. Quote
RetroCAD Posted October 23, 2019 Posted October 23, 2019 MD2020 - I have several early machines that I use with DOS. If I can be of any assistance in your migration I'd be happy to do it just to help out. Quote
Cheyanne Posted May 24, 2020 Posted May 24, 2020 I have used Ver 1 from 1986 to now and and I use Ver 4.2 ultra to save them into DXF You are right it is very easy to use The format DWG is not the format that Autocad uses. To run files in Autocad you have to import the DXF file. You also have to create a sym file in Drafix that autocad will recognise. Before it loads Quote
Si uk Posted May 28, 2020 Posted May 28, 2020 Hi, I am also a dinosuur using Drafix Ultra 4.20. Did you ever find a similar compatible program? Thanks, Si. Quote
mballes Posted July 28, 2023 Posted July 28, 2023 i ran this program in the late 80's early 90's. At the time we were inputting AT&T buildings into CAD(DWG)Format but could not afford AutoCAD. it had a graphical interface of sorts. Eventually had to bite the bullet and upgrade computers and but AutoCAD. I remember buying 2mb of ram for the PC to run AutoCAD V8 and the memory cost $2k, plus you hade to buy QEMM softwatre to run that much RAM. Doubt you could even buy 2mb of RAM these days. Quote
popzz Posted 7 hours ago Posted 7 hours ago I can run drafixcad v2.1 with emulator otvdm ( winevdm)16bit installed in windows 11 x64 found on github https://github.com/otya128/winevdm?tab=readme-ov-file Regards Pop Quote
