  2. @Danielm103, I'm on rev. 8.9.3 so does not apply to me. Thanks for the warning nonetheless. ymg
  3. Danielm103
    Notepad++ run time exension
    make sure you all have updated Notepad++, there was a security flaw, https://nvd.nist.gov/vuln/detail/CVE-2025-15556
  4. Danielm103
    Boundary command
    Not sure, you can hit the current vertex and iterate backwards, mine showed 228
  5. Today
  6. Welcome aboard, post a sample dwg with your block, then people can have a look at what you have done.
  7. @BIGAL, I am quite sure you settled your issue in N++ a long time ago. I was facing the same situation so maybe the following will be of interest to you. I am using NppExec to Validate and Load a file to Autocad. The NPPexec either save either a Selection or the Whole active window of Notepad++ in a tempfile called "D:\Lisp\NppVal.lsp". This has to be a trusted Autocad Location. NppExec then transfer execution to a PowerShell script called ValidateAndLoad.ps1. This script is placed in directory "C:\Scripts\ValidateAndLoad.ps1" . The powershell validates the lisp and then if valid, Load it in Autocad. It then Activate the Autocad Window and brings it into view. All that need to be done is to start the command you just loaded. To Activate and bring in View, all the usual command were failing until I found a little utility called nircmd. So that is what the ps1 script uses. You will need to downlad it from https://www.nirsoft.net/utils/nircmd.html and place it in same directory "C:\Scripts" as the ps1 script. Following is the NppExec script: npp_console 1 env_set NPP_FILENAME = $(FILE_NAME) // Get selection info sci_sendmsg SCI_GETSELECTIONSTART set local pos_start = $(MSG_RESULT) sci_sendmsg SCI_GETSELECTIONEND set local pos_end = $(MSG_RESULT) sci_sendmsg SCI_LINEFROMPOSITION $(pos_start) set local start_line = $(MSG_RESULT) // Create temp file for current context if $(pos_start) == $(pos_end) then // No selection: Save whole file sci_sendmsg SCI_SELECTALL sel_saveto "D:\lisp\NppVal.lsp" sci_sendmsg SCI_SETEMPTYSELECTION $(pos_start) cmd /c powershell -NoProfile -ExecutionPolicy Bypass -File "C:\Scripts\ValidateAndLoad.ps1" -FilePath "D:\lisp\NppVal.lsp" -ScintillaLine 0 -IsSelection 0 else // Selection exists sel_saveto "D:\lisp\NppVal.lsp" cmd /c powershell -NoProfile -ExecutionPolicy Bypass -File "C:\Scripts\ValidateAndLoad.ps1" -FilePath "D:\lisp\NppVal.lsp" -ScintillaLine $(start_line) -IsSelection 1 endif env_unset NPP_FILENAME Note: NPP script does not save your file by design, when debugging I don't want to Save. Following is the ValidateAndLoad.ps1 param( [string]$FilePath, [int]$ScintillaLine = 0, [int]$IsSelection = 0 ) $ErrorActionPreference = 'Stop' $TargetDir = 'D:\lisp' $TargetFile = Join-Path $TargetDir 'NppVal.lsp' $NirCmdPath = 'C:\scripts\nircmd.exe' $MaxRetries = 10 $RetryDelayMs = 300 if (-not $FilePath) { Write-Output "ERROR: No file path provided." exit 1 } if (-not (Test-Path -LiteralPath $FilePath)) { Write-Output "ERROR: File not found: $FilePath" exit 1 } try { $enc = [System.Text.Encoding]::GetEncoding(1252) $Text = [System.IO.File]::ReadAllText($FilePath, $enc) } catch { Write-Output "ERROR: Failed to read file: $($_.Exception.Message)" exit 1 } $FileName = [System.Environment]::GetEnvironmentVariable("NPP_FILENAME") if (-not $FileName) { $FileName = "Unsaved Document" } Write-Output "VALIDATING: $FileName" $level = 0 $inString = $false $inComment = $false $inBlockComment = $false if ($IsSelection -eq 1) { $line = $ScintillaLine + 1 } else { $line = 1 } $col = 0 $bracketStack = [System.Collections.Generic.List[PSCustomObject]]::new() $expressionStack = @() $global:defunCount = 0 function New-ValidateExpression { param( [string]$ExprText, [int]$StartLine, [int]$StartCol, [boolean]$IsQuoted ) $cleanText = $ExprText -replace "\([^\(\)]*\)", " #EXPR " $cleanText = $cleanText.Replace("`r", " ").Replace("`n", " ").Trim() $tokens = $cleanText -split '\s+' | Where-Object { $_ -ne "" } if ($tokens.Count -eq 0) { return } $firstToken = ([string]$tokens).ToLower() if (-not $IsQuoted) { if ($firstToken -like '"*') { Write-Output "ERROR: First element in expression cannot be a string literal at line $StartLine, col $StartCol" exit 1 } if ($firstToken -match '^[+-]?[0-9]+(\.[0-9]+)?$') { Write-Output "ERROR: First element in expression cannot be a numeric literal at line $StartLine, col $StartCol" exit 1 } } if ($firstToken -eq "setq") { $argCount = $tokens.Count - 1 if ($argCount -eq 0) { Write-Output "ERROR: 'setq' requires at least one symbol-value pair at line $StartLine, col $StartCol" exit 1 } if ($argCount % 2 -ne 0) { Write-Output "ERROR: 'setq' has an odd number of arguments ($argCount) at line $StartLine, col $StartCol" exit 1 } } } for ($i = 0; $i -lt $Text.Length; $i++) { $c = $Text[$i] $col++ if ($c -eq "`n") { $line++ $col = 0 } if (-not $inString) { if ($inBlockComment) { if ($c -eq '|' -and $i + 1 -lt $Text.Length -and $Text[$i+1] -eq ';') { $inBlockComment = $false $i++ $col++ } continue } if ($inComment) { if ($c -eq "`n") { $inComment = $false } continue } if ($c -eq ';' -and $i + 1 -lt $Text.Length -and $Text[$i+1] -eq '|') { $inBlockComment = $true $i++ $col++ continue } if ($c -eq ';') { $inComment = $true continue } } if ($c -eq '"') { $isEscaped = $false if ($i -gt 0 -and $Text[$i-1] -eq '\') { $slashCount = 0 $k = $i - 1 while ($k -ge 0 -and $Text[$k] -eq '\') { $slashCount++ $k-- } if ($slashCount % 2 -ne 0) { $isEscaped = $true } } if ($isEscaped) { if ($expressionStack.Count -gt 0) { $expressionStack[-1] += $c } continue } $inString = -not $inString if ($expressionStack.Count -gt 0) { $expressionStack[-1] += $c } continue } if ($inString) { if ($expressionStack.Count -gt 0) { $expressionStack[-1] += $c } continue } if ($c -eq '(') { $level++ $isListQuoted = $false if ($i -gt 0 -and $Text[$i-1] -eq "'") { $isListQuoted = $true } elseif ($bracketStack.Count -gt 0) { $isListQuoted = $bracketStack[-1].IsQuoted } $bracketStack.Add([PSCustomObject]@{ Line = $line Col = $col IsQuoted = $isListQuoted }) $expressionStack += "" if (-not $isListQuoted -and $i + 10 -lt $Text.Length) { $lookAheadSlice = $Text.Substring($i + 1, 10).ToLower() if ($lookAheadSlice -match '^\s*defun(-q)?(\s|$)') { $global:defunCount++ } } if ($i + 1 -lt $Text.Length -and $Text[$i+1] -eq ')') { $isDefunArgs = $false if ($expressionStack.Count -gt 1) { $parentExpr = $expressionStack[-2].Trim().ToLower() if ($parentExpr -like "defun*" -or $parentExpr -match "(^|\s)defun(-q)?(\s|$)") { $isDefunArgs = $true } } $isQuotedList = $isListQuoted if ($i -gt 1 -and $Text[$i-1] -match '\s' -and $Text[$i-2] -eq "'") { $isQuotedList = $true } if (-not $isDefunArgs -and -not $isQuotedList) { Write-Output "ERROR: Empty parentheses () found outside of a function definition at line $line, col $col" exit 1 } } continue } if ($c -eq ')') { $level-- if ($level -lt 0) { Write-Output "ERROR: Unexpected closing parenthesis ')' at line $line, col $col" exit 1 } if ($bracketStack.Count -gt 0) { $finishedExpr = $expressionStack[-1] $lastIndex = $bracketStack.Count - 1 $currentBracket = $bracketStack[$lastIndex] $bLine = $currentBracket.Line $bCol = $currentBracket.Col $bQuoted = $currentBracket.IsQuoted New-ValidateExpression -ExprText $finishedExpr -StartLine $bLine -StartCol $bCol -IsQuoted $bQuoted $bracketStack.RemoveAt($lastIndex) if ($expressionStack.Count -gt 1) { $expressionStack = $expressionStack[0..($expressionStack.Count - 2)] $expressionStack[-1] += " #EXPR " } else { $expressionStack = @() } } continue } if ($expressionStack.Count -gt 0) { $expressionStack[-1] += $c } } if ($level -gt 0) { $lastOpen = $bracketStack[-1] Write-Output "ERROR: Unclosed parenthesis '(' starting at line $($lastOpen.Line), col $($lastOpen.Col)" exit 1 } Write-Output "SUCCESS: Validated $global:defunCount function(s) successfully." if (-not (Test-Path -LiteralPath $TargetDir)) { New-Item -ItemType Directory -Path $TargetDir -Force | Out-Null } try { $enc = [System.Text.Encoding]::GetEncoding(1252) [System.IO.File]::WriteAllText($TargetFile, $Text, $enc) } catch { Write-Output "ERROR: Failed to write $TargetFile : $($_.Exception.Message)" exit 2 } if (Test-Path -LiteralPath $NirCmdPath) { try { Start-Process -FilePath $NirCmdPath -ArgumentList 'win activate stitle AutoCAD' -WindowStyle Hidden | Out-Null Start-Sleep -Milliseconds 500 } catch { } } $acad = $null for ($i = 1; $i -le $MaxRetries; $i++) { try { $acad = [Runtime.InteropServices.Marshal]::GetActiveObject('AutoCAD.Application') if ($acad) { break } } catch { Start-Sleep -Milliseconds $RetryDelayMs } } if (-not $acad) { Write-Output "ERROR: Could not attach to a running AutoCAD instance." exit 4 } try { $safePath = $TargetFile.Replace('\', '\\') $acad.ActiveDocument.SendCommand("(load `"$safePath`")`n") Write-Output "SUCCESS: Loaded $TargetFile" exit 0 } catch { Write-Output "ERROR: Failed to send load command to AutoCAD: $($_.Exception.Message)" exit 5 } Notes: Autocad has to running and a drawing open in order to load. If validation fails you are dumprd back to N++ with the NppExec console showing you where it fails. If you double click on the error line you cursor in N++ will go to that line. Bear in mind that the error location is not perfect, but you are normally in the right function. Finally to get the error lines and Success lines to appear in red, you have to set the NppExec Console Filters as shown in the below image. Phew!! that was a long post. ymg
  8. if Nothing else it would show up in peoples searches. just posting a file even tho it has great documentation will not show up in searches. if you take all the time to write things up and share here make it so people can find your lisp files. or just copy all the ;; lines. someone in 6 months to a year will post looking for a divide lisp with points and I won't be able to find this post. -Edit like you did here
  9. @darshjalal Thanks for your program contribution. I don't want to take away for your obvious hard work, but I somewhat agree with @BIGAL. I have read the extensive comments that are very detailed and technical, but there is no summary of what it is used for, or how it is useful. For the casual LISP user, they would not understand the value in such a program. I think a simple paragraph would be help instead of blindly evaluating it. Your title does explain the purpose of the program, but it's too vague and some plain language on how the features are helpful would be nice - just a friendly critique
  10. marko_ribar
    Boundary command
    @Danielm103 Why Properties palette doesn't show how many vertices does closed polyline have? That was always included AFAIK if I can recall correctly...
  11. Danielm103
    Boundary command
    creates a closed polyline in Autocad 2027
  12. mhupp
    Boundary command
    Does it create a closed poly? or is it open where the two lines don't meet.
  13. Why the error occurs The PAUSE limitation: In AutoLISP, pause only stops the command to let the user interact (e.g., click a point). It does not return the string value to the command sequence. When you reach the attribute part, AutoCAD expects a string, but since pause doesn't provide one, the sequence breaks.Multiline Attribute Format: Multiline attributes in a command-line sequence require specific formatting. If there are line breaks, they must be represented by \P. In Lisp, you must escape the backslash: \\P .Command vs -Command: When using Lisp, it is safer to use the hyphenated version (e.g., -INSERT ) to force the command-line interface and bypass dialog boxes entirely. The Corrected Lisp Routine This routine replaces your DIESEL script. It captures the date automatically (matching your DIESEL format) and prompts for the initials and notes. (defun c:REVNOTE (/ insPt dateStr userInitials revNote) ;; Save current ATTDIA and turn it off (setq oldAttdia (getvar "ATTDIA")) (setvar "ATTDIA" 0) ;; 1. Get Insertion Point (setq insPt (getpoint "\nSpecify insertion point: ")) ;; 2. Get Date (Mimicking your Diesel formatting) ;; This uses a Lisp trick to call the Diesel 'edtime' function directly (setq dateStr (menucmd "M=(edtime,$(getvar,date),DD.MO.YYYY)")) ;; 3. Get User Initials (getstring T allows spaces) (setq userInitials (getstring T "\nEnter Initials: ")) ;; 4. Get Revision Note (for the multiline attribute) (setq revNote (getstring T "\nEnter Revision Note: ")) ;; 5. Execute the Insert command ;; Sequence: BlockName, Point, ScaleX, ScaleY, Rotation, Attr1, Attr2, Attr3, Attr4 (command "-INSERT" "REVNOTE" ; Block name insPt ; User picked point "1" "1" "0" ; Scale and Rotation "P01" ; Attribute 1: Rev Index dateStr ; Attribute 2: Date userInitials ; Attribute 3: Initials revNote ; Attribute 4: Multiline Note ) ;; Restore ATTDIA and Regen (setvar "ATTDIA" oldAttdia) (command "REGEN") (princ "\nRevision inserted successfully.") (princ) ) Key Differences & Improvements: menucmd: This is the best way to get the exact edtime format you used in DIESEL without writing a complex date-parsing routine in Lisp. getstring T: The T flag allows the user to enter spaces (e.g., if the user wants to type "First issue - revised"). Without it, pressing the Spacebar would finish the command. -INSERT: Using the hyphen ensures that AutoCAD doesn't try to pop up a browser window for the block file.Multiline Support: If your revNote contains multiple lines, make sure to type \P where you want the line break, or modify the code to join multiple strings with \\P.
  14. SLW210
    Fields called from TAB Names
    It seems @Jesper Hedlund hasn't returned. If I am understanding correctly, the issue is with the program used to plot the layouts, it plots Model instead of the actual layouts CTAB value.
  15. SLW210
    Boundary command
    Worked fine on my home computer with AutoCAD 2000i, but I get the same as @PGia and @ronjonp on AutoCAD 2026 at work.
  16. Inside the code there is explanation of the code function. The code does many functions that image can't explain. Kindly check the code and read the description inside. Regards.
  17. If your offering something a good idea is to provide images or a movie about what the program does, else the "Why bother" will occur. Just attaching a lisp is not really describing why you should download the program. Think of it as if I was selling the program how would I get people interested.
  18. DIVCURVES-INSERTING POINTS AS SPECIFIC DISTANCE.LSP
  19. BIGAL
    LT slow, have you looked at doing saves say every 15 minutes as a test, your undo may be coming an excessive size. What is your auto save set to ? We had like 15 minutes as the default. Another where is your "Temp directory" pointing to I have a SSD and normal drive and the ssd is so much faster when saving.
  20. Yesterday
  21. ronjonp
    Boundary command
    AutoCAD 2027 still has the bug:
  22. I am a ROOKIE. So please take it easy on me. I've been searching and tried to replicate what others have said works for them with no luck. I'm trying to have 1 "MAIN" attribute that I am prompted to change the value when inserting the block. The other attributes "SUB1" and "SUB2" would update to match the value of the master. I have tried creating these attributes with the ATTDEF. I made the MAIN I then made the SUB1 with the Default a Field category OBJECT Field names Object Object type Attribute Definition ( which is where I can select the MAIN attribute) Property Value. I get the ---- in a Grey block I then select all 3 attributes and create a block with them. When I insert the block I get the prompt to change the value of MAIN and SUB1 & SUB2 have the ---- inside the grey boxes. The value of MAIN is updated but SUB1 and SUB2 still show the ---- Grey boxes. REGENALL amide no difference. I tried doing the same thing in the block editor and got the same results. I "ASSuME" it is just something easy that I am missing. If you can help that would be great. I have about 40 Attributes in 1 block that need to be updated with the value of the MAIN.
  23. mhupp
    Ouch. See what it does if you hit esc. or hitting the X instead of cancel.
  24. I'm writing a lisp routine to automation drawing revision in lisp. to replace a diesel version. I have come across a problem when inserting the block using lisp, in diesel it works perfectly. The block has four attributes, with the last being a multiline attribute. The routine stumbles at this point and misinterprets the pause for user input as \ and returns the error 'unknown command'. The diesel code that works is below. attdia;0;-I;REVNOTE;\;1;;P01;""$m=$(edtime,$(getvar,date),DD.MO.YYYY)"";SMS;First issue;;attdia;1;rea; The same in lisp below (command "attdia" "0") (command "_Insert" "REVNOTE" pause 1 1 0 "P01" Date Initials pause) (command "attdia" "1") (command "REA") Any ideas on why this is happening as i'm stumped, unless its a bug in AutoCAD. many thanks REVNOTE.dwg
  25. pkenewell
    Quick String Search
    @rlx Your Kung-Fu is Strong! Nice work!
  26. rlx
    Quick String Search
    Updated first post , added a few new options and killed a little bug in the get-subfolders routine.
  27. Last week
  28. PGia
    Boundary command
    I’m using AutoCAD 2015. "boundary" is supposed to return a perimeter exactly matching the geometry surrounding the point specified to the command. I run the command using the option to identify boundaries by 'pick' on screen. I haven’t tried exploding the polylines into lines yet. I’ll give it a try, but I suspect the result will be the same.
  29. mhupp
    Boundary command
    Must be an AutoCAD thing works in BricsCAD. you could just join the other 3 polys and get the same effect.
